hotrod69camaro
01-27-2013, 11:07 PM
67-69 Camaro Sub frame (https://www.pro-touring.com/classifieds.php?p%5Bmshow%5D=listing&p%5Bid%5D=67-69-camaro-sub-frame-6223)
67-69 camaro sub frame. This sub frame was removed from my car I've owned since 2000. It has had the Guldstrand mod done at the upper control arm attach pad. It has Speed Tech tubular upper control arms with stainless shafts and Del-rin bushings. It has Speed Tech tubular lower control arms. The steering box was sent to Lee Steering and reworked to add feel and change the steering ratio as well as a full rebuild. It has a Baer brake system with 13 inch two piece rotors with aluminum center hat, rotors are drilled and slotted with 4 piston calipers. 16 inch wheels fit over these brakes. I also have the correct master cylinder that came with this brake system and a 9 inch dual diaphram booster. I has a Baer tracker outer tie rod system to eliminate bump steer. It has a QA1 coilover shock setup with Global West springs and double adjustable shocks. Hotchkis hollow front sway bar with Guldstrand Hiem joint end links. All these parts that were added to this subframe have 5000 miles on them. Assembeled with ARP grade 8 stainless fasteners. $2500.00... (Also would like to sell the aluminum inner fenders I had fabricated that you see in the picture)...Call Mike..(714) 504-7315...Thanks
List Date: 1/28/2013
For more info, click here to view the original listing: 67-69 Camaro Sub frame (https://www.pro-touring.com/classifieds.php?p%5Bmshow%5D=listing&p%5Bid%5D=67-69-camaro-sub-frame-6223)
On Sale For: $2500 + $1 Shipping
https://static1.pt-content.com/images/noimg.gif (http://enthusify.com/protouring/listings/67-69-camaro-sub-frame-6223/purchase)
https://static1.pt-content.com/images/pt/2013/01/eQzfCqRMYQnr2-1.jpg (https://www.pro-touring.com/classifieds.php?p%5Bmshow%5D=listing&p%5Bid%5D=67-69-camaro-sub-frame-6223)
https://static1.pt-content.com/images/pt/2013/01/hc5cASW0425w2-1.jpg (https://www.pro-touring.com/classifieds.php?p%5Bmshow%5D=listing&p%5Bid%5D=67-69-camaro-sub-frame-6223)
https://static1.pt-content.com/images/pt/2013/01/1KVW8Yy41v4A2-1.jpg (https://www.pro-touring.com/classifieds.php?p%5Bmshow%5D=listing&p%5Bid%5D=67-69-camaro-sub-frame-6223)
https://static1.pt-content.com/images/pt/2013/01/EK6yC0UCnzn22-1.jpg (https://www.pro-touring.com/classifieds.php?p%5Bmshow%5D=listing&p%5Bid%5D=67-69-camaro-sub-frame-6223)
https://static1.pt-content.com/images/pt/2013/01/ZuU8anMfFA842-1.jpg (https://www.pro-touring.com/classifieds.php?p%5Bmshow%5D=listing&p%5Bid%5D=67-69-camaro-sub-frame-6223)
https://static1.pt-content.com/images/pt/2013/01/UvEDbhDHeKPj2-1.jpg (https://www.pro-touring.com/classifieds.php?p%5Bmshow%5D=listing&p%5Bid%5D=67-69-camaro-sub-frame-6223)
https://static1.pt-content.com/images/pt/2013/01/TZAETM3BaEua2-1.jpg (https://www.pro-touring.com/classifieds.php?p%5Bmshow%5D=listing&p%5Bid%5D=67-69-camaro-sub-frame-6223)
https://static1.pt-content.com/images/pt/2013/01/68qzntk14xzw2-1.jpg (https://www.pro-touring.com/classifieds.php?p%5Bmshow%5D=listing&p%5Bid%5D=67-69-camaro-sub-frame-6223)
https://static1.pt-content.com/images/pt/2013/01/eTP0vXjfmNhj2-1.jpg (https://www.pro-touring.com/classifieds.php?p%5Bmshow%5D=listing&p%5Bid%5D=67-69-camaro-sub-frame-6223)
https://static1.pt-content.com/images/pt/2013/01/8feDaQYu6Gn62-1.jpg (https://www.pro-touring.com/classifieds.php?p%5Bmshow%5D=listing&p%5Bid%5D=67-69-camaro-sub-frame-6223)
https://static1.pt-content.com/images/pt/2013/01/WCuVrPdmVgYV2-1.jpg (https://www.pro-touring.com/classifieds.php?p%5Bmshow%5D=listing&p%5Bid%5D=67-69-camaro-sub-frame-6223)
