View Full Version : powder coating used coil springs
kush69
01-27-2013, 05:15 AM
Does anyone think powder coating coil springs would stiffen the spring when baking it .Took the front end apart on my 69camaro new bushings ball joints, etc had 1 inch dropped springs already for a couple years powdercoated now the cars sits 2inces to high seems odd to me .Gonna go out and loosen all the bolts on the ground but curious what anyone else thinks Thanks
77thor
01-27-2013, 08:05 AM
I don't believe that powdercoating has anything to do with your issue.
Either you did not get the spring seated correctly in the upper control arm...
Or you tightened everything down when the car was up off the ground.
Anthony k
01-27-2013, 01:09 PM
400 degree heat used to bake powder will weaken the spring. Lowering it, possibly making it brittle. I have read and talked to a lot of people about this. As I didn't want to buy new springs. But will he doing so anyway
exwestracer
01-27-2013, 01:49 PM
Uhh, no... Look at any "ICE" or iron-carbon phase diagram, and you will see that nothing permanent happens to any kind of steel until you get above 1300F.
70667
How would your brake rotors (or steel oven rack!) survive????
kush69
01-27-2013, 01:57 PM
70667
I agree i didnt think it would be a prob its been a 2yrs since i had them done iam not new to building cars loosened all the control arm bolts and checked the spring pockets seems odd to me i drove on them for at least 5000 miles before i took it apart
kush69
01-27-2013, 01:58 PM
off to the garage Thanks
regal454
01-27-2013, 04:27 PM
[QUOTE=77thor;966211]Either you did not get the spring seated correctly in the upper control arm...
[QUOTE]
I agree. Check the inspection holes on the upper spring seat to make sure the coil is seated properly.
