View Full Version : SBC top end kit
chevelle375
01-25-2013, 11:05 AM
SBC top end kit (https://www.pro-touring.com/classifieds.php?p%5Bmshow%5D=listing&p%5Bid%5D=sbc-top-end-kit-6049)
A lot of power and dependability
400-475 hp has been achieved !
PAIR OF PBM ERSON STRIKE FORCE SBC ALUMINUM HEADS:
PORTMATCHED to a FELPRO 1205 gasket
Straight plug or Angle plug
200cc intake runner
64cc chambers with improved flow chambers
Stronger Pressure casted Aircraft grade 356A aluminum alloy heat treated to T6 specs
I HAVE SPINTRONED THESE HEADS TO 8500 RPM WILL HOLD UP TO SOME SERIOUS ABUSE!
Harden valve seats
Bronze valve guides
Accepts center bolt and rail type valve covers
Standard accessory bolt holes
Plus .400 thick deck for severe uses
2.02 1 piece intake valves
1.60 1 piece exhaust valves
Valves are one piece forging EV-8 stainless steel alloy
Undercut stems powerflow design for improved flow
Fully machined and swirl polished stems
ERSON RACE SPRINGS SET UP FOR .550 LIFT 135# at 1.800
CHROME MOLY RETAINERS and KEEPERS
7/16 19000 SCREW IN STUDS AND GUIDEPLATES I RECOMMEND 7/16
POSITIVE VALVE STEM SEALS
PBM HEAD BOLT KIT WITH TEFLON COATED THREADS
1205 FELPRO INTAKE GASKETS
FREE PORTMATCH TO A 1205 FELPRO INTAKE
PROFESSIONAL PRODUCTS ALUMINUM CROSS WINDS INTAKE MANIFOLD (AIRGAP)
HURRICANE INTAKE ADD 40.00 USD
DUAL ROW PRE STRECHED , HEAT TREATED PBM ERSON ADJUSTABLE TIMING SET
SET OF PBM ERSON PERFORMANCE HYDRALIC LIFTERS
5/16 Pushrods .100 LONG .065 WALL
FULL FELPRO PREMIUM GASKET SET FOR ALUMINUM HEADS <LOWER END GASKETS
CHROME VALVE COVERS
PERFORMANCE ERSON CAM SHAFT 230/230.480.480 ..
.MORE CAMS TO CHOOSE FROM FOR SAME PRICE
PBM PERFORMANCE CAM LOCK KIT
1.5 ERSON FULL NEEDLE BEARING
ALUMINUM RACE ROLLER RACE ROCKER ARMS PROVEN FOR PERFORMANCE
List Date: 1/25/2013
For more info, click here to view the original listing: SBC top end kit (https://www.pro-touring.com/classifieds.php?p%5Bmshow%5D=listing&p%5Bid%5D=sbc-top-end-kit-6049)
On Sale For: $1200 + $0 Shipping
https://static1.pt-content.com/images/noimg.gif (http://enthusify.com/protouring/listings/sbc-top-end-kit-6049/purchase)
https://static1.pt-content.com/images/pt/2013/01/QzUSsjJz4FU5JPG-1.jpg (https://www.pro-touring.com/classifieds.php?p%5Bmshow%5D=listing&p%5Bid%5D=sbc-top-end-kit-6049)
https://static1.pt-content.com/images/pt/2013/01/hUanSkkHzQBPJPG-1.jpg (https://www.pro-touring.com/classifieds.php?p%5Bmshow%5D=listing&p%5Bid%5D=sbc-top-end-kit-6049)
SicMonte
01-30-2013, 10:26 AM
How much for just the heads? pm me
Blue89Bird
02-03-2013, 11:46 AM
Where in NJ? How do you think this would work on top of a 68 327?
chevelle375
02-04-2013, 11:17 AM
I'm located in Hazlet, NJ. I think it will work fine on your 327.
