View Full Version : 1969 Nova project- it has a front wing so....yeah it's PT
NOPANTS-68
01-25-2013, 09:44 AM
I've decided to part with my '69 Nova I've been working on. I found this car as a legit barn find in northern California about an hour from my home. I knew as soon as I saw it, it was a perfect candidate for a build. It hasn't been on the road since 1983/84 and was very solid. It's a roller so no engine or trans. The car comes with almost a full set of trim and all of the glass except for the windshield. The window regulators are in excellent shape and fully functional. The glass is not cracked or delaminated. No front seat, but the rear bench is intact. The dash cluster is dirty but complete and has the controls for the heat/vents. The doors are extremely solid and have zero delfection in the hinges whatsoever. Other than shopping cart dents and door dings, the body is in original shape and currently in dark gray sealer after have been stripped with 120 grit. There is zero evidence or any noteworthy collision as the doors, hood, and trunk all retain crisp, original gaps. They all open and close perfectly. The hood gaps and latch are perfect. While there are many simple dents, the car will not require and further panel replacement and most importantly has NEVER had any bodywork or filler applied to it. What you see is exactly what is there. I have completed the following metal work:
New Goodmark full floor pans
New Goodmark rear tail lamp panel (original was cut for custom lamps-yeah)
New Goodmark right, lower quarter panel patch
New Goodmark upper dash panel at cowl
Left quarter patched over wheel arch (had two small bubbles)
-rt front inner fenderwell has typical battery damage. Needs replaced.
All panels have been etched primed at the seams and seam sealed with Kent 6000 products. The car is now completely rust free other than a small spot on the front edge of the hood and the rt fenderwell (batter acid damage). I had planned on a Goodmark hood to replace it. The trunk floor has some minimal discoloration and some minor pitting, but does not justify a pan replacement. The roof had some small spots where corrosion had begun, but will not require anything more than metal to metal to make prefect. The car is originally a V8/auto/10 bolt car. The 8.2 10 bolt is still there as well as the multi leafs. A clear CA title in my name is on the way from DMV. All fees are paid. The subframe in the car is in perfect shape. It doesn't have any scars from being towed or damaged. I don't think it's ever left the body. The car steers and rolls on 4 good rollers. It's the perfect builder to take from here. The dirty work is done. It's ready for body and paint!
$3900 or offer with title and a pile of extra parts. Dave 916-300-09nine nine
Sacramento, CA
Bonus!- Check out that legit, vintage pro touring front wing! I'll throw it in!
https://static1.pt-content.com/images/pt/2013/01/ltfront_zpsaaf38465-1.jpg
https://static1.pt-content.com/images/pt/2013/01/rearquarter_zpsca04ea57-1.jpg
https://static1.pt-content.com/images/pt/2013/01/hoodgap1_zpsfba230ac-1.jpg
https://static1.pt-content.com/images/pt/2013/01/engbay1_zpsc18c2b32-1.jpg
https://static1.pt-content.com/images/pt/2013/01/floor2_zpseb1efd84-1.jpg
https://static1.pt-content.com/images/pt/2013/01/rtsideview_zps7b45b242-1.jpg
https://static1.pt-content.com/images/pt/2013/01/quarterpatch_zps8333ccd8-1.jpg
https://static1.pt-content.com/images/pt/2013/01/novaextras_zpsd97977ec-1.jpg
https://static1.pt-content.com/images/pt/2013/01/trunk1_zps774b63fe-1.jpg
https://static1.pt-content.com/images/pt/2013/01/ltside_zps23a08f3a-1.jpg
https://static1.pt-content.com/images/pt/2013/01/dash_zps14757666-1.jpg
https://static1.pt-content.com/images/pt/2013/01/rtfront_zpsc39873dd-1.jpg
cornfedbill
01-25-2013, 09:53 AM
It's good to see another Nova.
NOPANTS-68
01-26-2013, 07:19 PM
Thanks Bill. It'll make someone about as solid launch pad as you could find. Wish I could keep it.
NOPANTS-68
01-31-2013, 08:11 PM
Got the new CA title today! She's legal. New price- $3500
HeadInTheClouds
02-05-2013, 05:03 AM
I wish some of these projects were near Montana! Looks like a great start
NOPANTS-68
02-07-2013, 08:39 AM
Gonna sweeten the deal a bit gents. I'm adding a CPP front disc brake kit. It'll include 2 inch dropped spindles, calipers, brackets, hardware, and booster/master. $3500 or best offer. Thanks PT.com
NOPANTS-68
02-15-2013, 08:17 AM
Friday bumpitude. I'm open to offers.
NOPANTS-68
02-20-2013, 01:36 PM
As per the request of a couple guys- here's a couple shots of the underside. As you can see, the car is all original aside from the new floors.
https://static1.pt-content.com/images/pt/2013/02/under1_zps532fc78a-1.jpg
https://static1.pt-content.com/images/pt/2013/02/under2_zpsa538ba19-1.jpg
https://static1.pt-content.com/images/pt/2013/02/under3_zps684a30ba-1.jpg
https://static1.pt-content.com/images/pt/2013/02/under4_zps099763c5-1.jpg
https://static1.pt-content.com/images/pt/2013/02/under5_zps98f01ca1-1.jpg
https://static1.pt-content.com/images/pt/2013/02/under6_zps552f5150-1.jpg
https://static1.pt-content.com/images/pt/2013/02/under7_zps5b389d3a-1.jpg
https://static1.pt-content.com/images/pt/2013/02/under8_zps8f2a5631-1.jpg
https://static1.pt-content.com/images/pt/2013/02/under9_zpsee07d6ff-1.jpg
https://static1.pt-content.com/images/pt/2013/02/under10_zps896a7708-1.jpg
NOPANTS-68
03-30-2013, 08:06 AM
Just added a legit, mint OEM SS396 L-78 hood with the louvers. They are very rare and I fits perfectly. $3500 and I'll also throw in the POR-15 clean and sealant paint kit I bought for it. Cheers
NOPANTS-68
05-14-2013, 03:08 PM
Just finished all of the POR-15 work and it looks brand new. Someone take this home before I COPO it.
https://static1.pt-content.com/images/pt/2013/05/floors_zps270c0fe8-1.jpg (http://s394.photobucket.com/user/silverback427/media/floors_zps270c0fe8.jpg.html)
no go nova
05-14-2013, 08:51 PM
Wish you were closer to sc
NOPANTS-68
05-14-2013, 09:27 PM
only a short truck ride away! lol
NOPANTS-68
06-03-2013, 06:08 PM
TTT- $3000- found something else I can't live without.
BLWN1
06-06-2013, 05:49 AM
May be interested depending in shipping, I need to look over pics on my computer when I get home..
Chris
[email protected]
NOPANTS-68
06-06-2013, 09:53 AM
Car just sold. Looks like it's staying local. Thanks PT for the board space.
