View Full Version : Triangulated 4 link question
mitch_04
01-22-2013, 05:45 PM
Hi everyone,
First off I'd like to thank everyone who posts on this site, I've learned a lot by browsing around. I'm about to build my first triangulated 4 link, although it isn't going to be on a pro-touring car. The suspension will be on an 85 C-10. My question is about the upper links. I have read that you do not what the axles upper links near the frame, you would want them near the differential. The reasoning for this is, I believe, that it would have an infinite instant center.
My question(s) is this: If I were to mount the axles upper links near the frame, what would the "seat of pants" difference be while driving? If I could go this route I would be able to mount longer links at a greater angle, helping me stay centered throughout the entire range of travel. The pickup will be bag on bar, and my main goal is to lay frame for shows with my secondary goal to be getting the best geometry available without hindering the main goal. If I have to go with the links near the differential, I would have to go much, much shorter since the frame is very narrow.
I do plan on building a pro-touring third gen Camaro, but until I find one in my price range I will learn on my pickup project.
Thanks for the help,
Mitch
mitch_04
01-23-2013, 07:00 AM
50 views and no replies, it must be either a very dumb question or a decently tough one. I saw my terminology was incorrect, what I'm looking for is in instant center, but roll center. What would the infinite roll center feel like to the driver. If I'm missing something here, please correct me.
exwestracer
01-23-2013, 09:08 AM
Mitch, the "infinite" roll center really isn't infinite. Sorry I didn't get back to you on this over on Lateral G. Wherever the upper links converge is the "fixed" point in the system. Everything revolves around that point. Let's say in your case the converge point is 48" ahead of the rear axle. If the rear really flexed out (like with a 4 channel air system), you would see some side motion of the axle. If the link angles get below 30 deg (60 deg total) you will be putting a lot of strain on the rod ends or bushings in hard cornering. In everyday driving, you probably wouldn't notice.
Rod
01-23-2013, 09:21 AM
pick ups are HOT now keep building, having the upper links closer to the frame and further away from the pumpkin will create bind and that can be reduced with the use of hiem joints, but the centering advantage of having a triangulated 4 link is reduced now making the system closer to a parallel 4 link an will require a centering device such as a panhard, watts or mumford link
mitch_04
01-23-2013, 11:38 AM
If I go with my upper axle links near the frame, and build a crossmember with a driveshaft loop, I will be able to have my front upper links, which would be triangulated, very close together. The links I'm using have a bushing on one end, and a "super pivot" on the other (think Johnny Joint). This should help my deflection, and I'll probably run the bushing on the frame side to help with transmitted vibrations. I should have no problem getting 60 degrees with my crossmember mounted front links. I don't plan on ever running air low on individual corners, and I doubt I'll every corner hard enough to get bind. This pickup will be mainly a fun project that hits the ground for shows, and looks good for cruising. I'm going to plug in the specs for the front end into the suspension analyser and see if there is anything I can tweak there as well.
Thanks for the help everyone, I'm diving in this weekend so it was great to get the info in time!
mitch_04
01-27-2013, 10:42 AM
Well, I spent the better part of the day with graph paper and a ruler. The old leaf spring suspension is out, lower links are mounted on the new-old 12 bolt axle, and I just have the upper links and new crossmember left. I ended up with lower links parallel to the ground, 30", uppers are 70% of lowers from side view with 60 degrees between them, and angled down to give me a roughly 60% anti-squat. Lowest spot on the frame is about 7-8" off the ground at ride height. It's incredibly exciting finally seeing it at the height I've dreamt of since I began the project.
exwestracer
01-27-2013, 11:21 AM
"like"
MonzaRacer
01-27-2013, 11:32 AM
Im have Ridetechs parallel 4 link and I am looking into redoing it and using a Fays2 style Watts link later on and doing away with Panhard bar. But time and funds and how my knee and shoulder heal.
mitch_04
01-27-2013, 05:35 PM
If I ever build another slammed pickup, I'm going to go crazy on the suspension. I don't know if you've seen a double Watts link, but they look pretty insane. I'd also have a cantilever setup and just generally have fun with it, care a little less about performance, more about style.
Anyways, I had to do a little modifying from my original plan as I built it. I haven't been able to do much measuring, but I think I'll still be OK. One big mistake I made was my rims and tires. I designed the suspension around the wheels and tires I will be buying, which will be an 1.5" inches taller. When I leveled my lower links, I didn't think of that, so I will have to adjust the mount down the road, raising it .75". My pinion angle may be off a little bit as well, but I left 3/8" threads showing on all my links so I can adjust that back into spec. Now everything is tacked in, I didn't have time to finish weld or mount my air springs, but that shouldn't take much time. Unfortunately, I have National Guard drills next weekend and the obvious, Super Bowl! I may sneak it in the shop during the week, we'll see. I might get some pictures on here, but I'm not very happy with how some of my welds turned out. It'll be strong enough, but they aren't pretty in any way.
exwestracer
01-28-2013, 05:21 AM
Mitch, please explain the "double Watts link" you are referring to. I designed one for a student to hold the airbag itself in place. I've never seen another one, so I'm curious. Got any photos?
mitch_04
01-28-2013, 06:02 AM
I saw it in "How to make your Muscle Car Handle". I don't have any pictures, and maybe there is an actual name for it. It is like having 2 Watts links, one on each axle tube, and linked together in the middle. It is suppose to nearly erase the small bit of movement you get from a regular Watts link. I don't think it's complexity is worth it's benefits as far as manufacturing goes, but it definetly looks cool.
Unfortunetly, it looks like I will have to re-do my upper links. Somewhere between the graph paper and the welder my measurements changed and they need to go wider on the axle.
exwestracer
01-28-2013, 07:33 AM
This?
70709
mitch_04
01-28-2013, 09:49 AM
Y'up, looks a little different in the book but operates the same. I looked it up and it is called a Mumford link, was already posted earlier in this thread and I didn't even notice!
mitch_04
01-28-2013, 09:54 AM
Just out of curiosity, or maybe future reference, how would you set up those? A regular watts link should have the bars parallel at ride height (I think), but those seem to be 45 degrees.
Norm Peterson
01-28-2013, 12:54 PM
I believe you set the two long links to be at mirror-image slopes to each other (with the long links being of equal length). The same really applies to a Watts link, with "horizontal at static ride height" being the unique situation where the mirror image to exactly horizontal is . . . exactly horizontal.
Didn't see this until today.
Maybe I missed it, but is there any plan view skew to your lower arms? Whether there is, and if so which way they converge will make for changes in axle steer and some differences in feel. Something else to think about, beyond whether the axle will shift laterally by enough to notice (and FWIW I'd build a little extra margin into all of the brackets as the plan view angle between the uppers drops much below 90°).
Norm
mitch_04
01-28-2013, 01:59 PM
I'm still trying to catch up on some of these terms. Plan view is overhead, and by skew are you asking if they are at an angle? My lower links are parallel, and the uppers are triangulated. I need to bring it back in the shop to remount something things. I raised my rear axle until it bottomed on the c-notch to make sure my brackets would clear the frame, but I had my pinion angle at 3 degrees when I tacked my upper brackets to the axle. Of course, when I lowered it to ride height, set my pinion angle back to 3 degrees (I didn't have my uppers installed yet, just mounted brackets) now my brackets were way off.
The next day I spend in the shop will consist of making small "jack stands" to hold the frame at ride height. I had been using our lift, but it apparently has air in it and likes to settle during alignment, which makes trying to figure out why your angles are off very tricky. Next I will put 3/4" wood under the tires to simulate the 1.5" taller tire that will be on it later and re-level my lower link frame bracket. It should just need to come up the same 3/4". Next I will raise the rear end to the highest it will go and re-mount my upper links so that they are wider on the axle end. I can't go any narrower on my crossmember, my driveshaft has to pass through and since the 12 bolt rear ends pinion is offset about an 1" of centerline, I have to go wide.
Just wanted to say it feels awesome to have some of the (in my opinion) experts of the forum answering my "beginner" questions. A lot of the time the experienced people don't want to spend time with simplier questions.
Also, I won't be running a Mumford on this, I was just curious in case I find someone who wants me to build a wild rear suspension. I'm thinking the Mumford and some cantilevering with horizontal coilovers would fit the bill.
exwestracer
01-30-2013, 06:54 AM
Mitch,
On the Mumford setup, the link angle defines the roll center height (much like your triangulated links define the R/C location). Other than that, the links don't "have" to be at any particular angle. Check out the "Separating ride from roll" thread in the Advanced Performance forum.
mitch_04
02-09-2013, 09:11 AM
Alright, back in the shop today and hitting a bit of a road block.
Question #1 - If I'm not able to get a full 60 degrees between links, what is the downside? Lateral axle movement, binding, or...?
Question #2 - I have my lower links mounted directly below the axles, center of joint being about 2" below bottom of axle. I may be able to get closer to 60 degrees if I take the upper link mounts, which are currently locating the upper joint directly above the axle, and move them closer to the front of the axle, rotating them forward from a side view. This will decrease my torque effect, but will it be a problem since the upper links are in tension during accel and only really hit hard during hard braking?
My C-notch is limiting my ability to go wider, but I have room ahead of the axle in the C-notch area. I could go wider if I go more towards the front of the axle with my upper mounts, vs being on top of the axle currently.
I checked on binding by setting my pickup at ride height and jacking up one side until the top of the axle hit the c-notch, no binding. This is through a 10" range of motion, something that it would probably never see unless I'm parking it crazy at a show. Gotta love them Johnny Joints!
exwestracer
02-09-2013, 11:08 AM
1) More likely to have some lateral movement, but the upper johnny joints will help with that.
2) How close to 60deg are you? The amount you could gain by safely rotating the link mounts forward probably won't help all that much.
mitch_04
02-09-2013, 01:15 PM
I wish I could draw on here, basically when my pickup is slammed for show I have about 2" ahead of the axle before I hit the c-notch. I either have the upper link mount directly above the axle and inside the frame, or rotate it slightly forward and it allows me to go about 1-2" wider. I was only at 42 degrees :( I have shortened a couple brackets that allows me to get a little closer on the front upper links, and also a little wider on the upper rear. I'm not going to change my link length, I'm at about 75% of the lower, so I'm trying to shoehorn the brackets as close as I can. Luckily, the pickup will never get driven at it's lowest setting, so if I do rub a bracket I'm ok. It will have about 8" of clearance at ride height. Hopefully I will have a pic by the end of the weekend of a finished rear suspension, even if it is just tacked in.
mitch_04
02-09-2013, 02:12 PM
Got 55 degrees! I'm thinking that's all I'm getting, it's really pushing it where it is at. I did rotate the upper links, I'll have to brace them well to make sure they stay put, they aren't much above axle centerline.
mitch_04
02-10-2013, 07:56 PM
Some pictures, it's my first time so be gentle. Well, building a suspension that is! I have everything tacked in, and I do plan on trimming a few more things. I will be adding a crossmember to my plates, a driveshaft loop, and whatever else comes up. The pinion is offset on the 12 bolt, unknown to me until I triple checked my axle being centered. I have a 2 degree pinion angle at ride height, roughly 12" of travel, and no binding so far. So far I think it has turned out pretty well for my first. You can see what I am talking about with the joints ending up right in the nook of the c-notch.
https://static1.pt-content.com/images/pt/2013/02/HPIM2960_zpsb260bb32-1.jpg
https://static1.pt-content.com/images/pt/2013/02/HPIM2958_zps801f84d8-1.jpg
https://static1.pt-content.com/images/pt/2013/02/HPIM2961_zpsa24fe840-1.jpg
https://static1.pt-content.com/images/pt/2013/02/HPIM2962_zpsfa95ac53-1.jpg
mitch_04
02-10-2013, 07:57 PM
Oops, second picture is my first set up when I didn't have the separation angle I needed. All others are final set up.
Norm Peterson
02-11-2013, 03:48 AM
Any reason why the C-notch couldn't be extended a little further forward to gain a little more clearance. Is there enough room to accommodate vertical suspension movement without contact occurring?
At 55° angle between the links, the forces in them will be almost double what they'd be at 90° included and about 10% higher than at 60°.
You might want to find out what the angle between the uppers on the Fox Mustang was (I think it was somewhat less than 90°). They converged the other way, but the force multiplication would be by the same logic = 1 / tan(half the included angle)
Norm
mitch_04
02-11-2013, 06:10 AM
The c-notch could have been extended further ahead. There are a few reasons to why I'm where I'm at. If this was going to be more Pro-touring than a cruiser to take from show to show, I would have done an entire raised back half with a raised bed floor. Well, I would have built an entire frame, that c-channel is unreal flexible! I can't do a raised bed floor on this because I'm going to be putting my subwoofers in the box blowing through into the cab and I need the floor to box top height. Obviously this goes to show that it is not a pro-touring pickup. I'm using it as a project to learn on, I'm not trying to have it perfect by any means. It will probably never see a hard corner, but I still wanted to build it the best I could while achieving my main objective of laying frame. Definitely learned a lot. The links have tons of room before they would ever hit the c-notch. The notch was designed to lay frame on a 30.5 inch tire, and until I can buy the rims, it has the stock 28.5 inch rims. With an 8" notch, I could lay frame on a stock tire, but my future tires made it necessary to build a 10" notch. The body and frame will hit the ground before the upper rear link would hit the frame, and I would have to have no air in the bags. At ride height I believe I have 7" before any contact, whether it's frame, body, or links. I think a bag would have to explode to make that happen.
Now the forces you are talking about, would that be the axles wanting to move laterally in a turn, trying to shear the upper link brackets off the axle? If so, I'll make sure to brace it as best I can to resist that.
On a side note, do most of the aftermarket vendors (The trustworthy ones) achieve 90 degrees on their kits? I would have had to had incredibly short links!
exwestracer
02-11-2013, 07:30 AM
Mitch, what is your plan for getting the driveshaft past that crossmember? Keep in mind that there is still a lof of pulling force against the upper links, so just cutting the crossmember away until the driveshaft clears isn't the best idea...
mitch_04
02-11-2013, 08:30 AM
I had planned on creating an oval loop of thick flat steel. The driveshaft moves from below to above the crossmember when it goes from lowest to highest. I had planned on cutting away the top and bottom, dropping my loop in, welding the top and bottom, cutting out the center, then finish welding the center. That way it will have contact all the way around prior to being welded.
mitch_04
02-11-2013, 08:31 AM
I do also plan on triangulating the crossmember with braces running just off center to the frame ahead of the crossmember.
exwestracer
02-11-2013, 12:44 PM
Good idea.
mitch_04
02-11-2013, 01:49 PM
Just wanted to say thanks again, you guys are a huge help. Absolutely love this site, after spending hours in the project updates I've went from thinking a C-5 suspension in a vehicle would have been impossible to wondering what I should try to put one in.
mitch_04
03-10-2013, 03:20 PM
Enough bracing?
https://static1.pt-content.com/images/pt/2013/03/HPIM2997_zps57c59ada-1.jpg
https://static1.pt-content.com/images/pt/2013/03/HPIM2998_zps09689239-1.jpg
https://static1.pt-content.com/images/pt/2013/03/HPIM2999_zpsd847f1e6-1.jpg
I may put a couple more round tubes to triangulate the rear c-notch bar to the front. I was having a blast doing all of this, I may have overdone it a little! Oh well, overkill is underrated. It's just so much fun, I've been wanting to do a huge build like this since I was probably 11 or 12. I finally am doing one that's up to my standards, which seem to far outweigh any of my "car buddies". Most of them just get a vehicle running, through a 15 ft paint job on it, and call it good. I've been reading Hot Rod magazine and the like for way too many years to keep it that simple....although I could have built about 3 cars in the same time!
Might as well throw one in of the vehicle as it sits. I have officially hit my main goal, rockers are touching.
https://static1.pt-content.com/images/pt/2013/03/HPIM2993_zpsd2e72d90-1.jpg
https://static1.pt-content.com/images/pt/2013/03/HPIM2992_zpsb8f090e1-1.jpg
agto8u
11-14-2013, 12:35 AM
Cool build. I'm in the process of building my rear suspension and fabbed up some brackets similar to yours ( the ones attaching the control arms to the axle and crossmember). I found it was a pita to align them and I didn't think they would be sturdy enough. So I made these. Just thought I'd give u an idea. I can post more pics if u need. The other end is radiused to the diameter of the axle tube and at the appropriate angle.
851678516685165
mitch_04
11-14-2013, 05:26 AM
I have since welded on a "cap" to my link brackets tying them together and triangulating them to the crossmember, but thanks for the idea. Next time I build a suspension I will build my own link brackets vs using the ones that come with the kit. It was easier for me to learn by getting the kit, but now that I know what I want I'll do it a little differently.
