View Full Version : 315's on 10" wheel
Blue Oval Man
01-21-2013, 07:20 PM
https://static1.pt-content.com/images/pt/2013/01/xlr_westcoast-1.png
Mr Nick
01-21-2013, 07:30 PM
Are you asking if it's ok to put a 315 on a 10" wide wheel?
I wouldn't suggest it. I have 285/40/18 on 18x9 in the rear, and there is a fair amount of bulge to the sidewall. A 315 is 30mm wider but the 10" rim is only 25mm wider, so you'd have even more bulge.
Blue Oval Man
01-21-2013, 07:37 PM
Thanks. Somehow I didn't get my question to come up in the tread. I see I somehow posted a second tread with the info.
Anyway, thanks. That was what I was wondering about was budge and how the tire would act as speed or on an autox coarse.
David.
Rod
01-21-2013, 09:44 PM
315 millimeters (mm) = 12.4 inches (1 inch = 25.4 millimeters) that's a lot of tire 1 inch of bulge on both sides! of a 10inch rim
Gitter Dun
01-22-2013, 08:37 AM
An advertised 10" wheel is not 10" wide and the wheels will run wider than advertised. The tire fitment goes by measured wheel width not advertised.
Measure from inside to inside of lip and then look for "measured wheel width" on the manufacturers tire spec list for the specific size tire you are looking for.
Blue Oval Man
01-22-2013, 02:07 PM
Unfortunately Intro doesn't have any specs on any of their wheels on their website and they don't seem to answer e-mails either. I wil phone when I have time but can't seem to find time during business hours.
Gitter Dun
01-22-2013, 05:16 PM
Wheel companies dont typically give actual width specs(you need to call for that info) but most tire manufacturers do. If you cant get a hold of Intro call Zak at Boze Wheels. Best customer service for wheels on the planet. I'd be running Bozes but the wheels Zak carried didn't come in the size I needed. Good luck!!
