View Full Version : Took apart my steering column
EL T1
01-17-2013, 11:33 AM
Dont remember where this ring went. Its a steel ring/spacer. Can anybody help me out. Thanks in advance. https://static1.pt-content.com/images/pt/2013/01/2le62x-1.jpg
EL T1
01-17-2013, 01:02 PM
This is on my 71 Camino, no tilt.
Rod
01-17-2013, 01:23 PM
hopefully some can help, did you look in or own the El Camino/Chevelle assembly Manual? Its also is in the Chassis Manual for that car, the steering column/ and posi unit are the only 2 things I sent out for rebuild
Sinnister69
01-17-2013, 02:11 PM
i have that on my 69 non tilt column. i believe if i remember correctly it is the bearing thrust washer
no. 11
http://www.camaros.net/forums/showthread.php?t=95769
EL T1
01-17-2013, 05:00 PM
I think it goes under this spring. I know it needs to bring the steering wheel away from column. Because, the hub on the grant wheel is rubbing the column when I turn..
EL T1
01-17-2013, 05:02 PM
https://static1.pt-content.com/images/pt/2013/01/15yzsz8-1.jpg
birdsandbowties
01-18-2013, 03:32 PM
i can help you out, i have quite a few non tilts and parts, give me a ring in the evening at 850-564-0072, Jim
V8240Z
01-25-2013, 09:42 AM
Did you figur out where it goes?
