View Full Version : 1966 Chevelle Pro Tour, Frame off, LS1-6 speed, a/c and more.
classiccarcustoms
01-12-2013, 05:17 PM
Were to start?
**Frame and suspension now 100% installed and today I will install the LS1, 6 speed, new clutch and set the new frame under the painted body so it will be a complete roller.******** 1-12-2013
I have a frame off 1966 Chevelle (136), sanded down to metal. Every part and bolt was painted off the car, inside and out. Fire wall is completely smoothed. Moved all hydraulics inside the car with custom pedals. Under side of car was sprayed by Line X bed liner and was tinted the color of the car. Look very nice.
Inside of the car was sprayed with the same but Black. This car is sealed up.
Frame was removed, sand blasted. Frame was then boxed all the way to the back and custom cross member made. then powder coated Black.
Suspension:
Front- Heidts upper and lower tubular control arms, QA1 adjustable coil overs, Heidts 2" drop spindles "Tall" ones for better camber, Heidts big sway bar and UniSteer rack and pinion set up.
Rear- Heidts upper and lower 4 link control arms with big sway bar, QA1 adjustable coil overs. Currie Ford 9" rear end with 3:73 posi.
Brakes:
Front- C-5 Corvette 13" 4 brakes with drilled and slotted rotors.
Rear 13" brakes with E-brake and drilled and slotted rotors as well.
Motor and trans:
2002 Corvette LS1 with 48,000 miles, drive by wire. Reworked wiring harness and ECM, gas pedal and TAC module. Coated S&P headers. Complete belt set up with vintage a/c kit.
2002 Camaro T-56 with new fly wheel and clutch.
Complete Vintage a/c kit.
Flaming river tilt steering column.
American wire, modern wiring harness. New in the box.
Ricks stainless gas tank with built in G.m fuel pump and sending unit, bolts into the factory spot.
Corvette fuel filter kit.
$3500 of new parts from OPG: I.E all new felts, rubbers, seals, gaskets, bumpers, complete light assemblies, emblems, tail lights, dash pad, dash bezels and chrome and so on.
Custom made drive line.
Brand new in the box Dakota Digital VHX Instruments in a blue color with carbon fiber back. Looks great.
EMS billet hood shocks
Ring Brothers billet door strikers
Fesler billet hood latch
Complete stainless bolt kit
I have modified the tunnel for the T-56. The whole car was built before paint and then pulled apart for paint. So it is just bolt together and have the baddest 66 chevelle.
I will bolt the frame back under the car for transporting. Frame is all done, 100% roller and every thing new and detailed. Just install motor and tarns and all new parts.
I have the stock interior, bucket seats front and stock rear. Needs recovered.
Every part that you could un-bolt is powder coated or new.
Clean CA title. One of a kind. Car is as in pictures. I will put frame back under it so it is a roller. You will need another tuck for all the other parts.
$38,000 or part trade.
Selling because father in law is sick and I need to finish his 34 coupe.
831-704-7331
NO calls after 8:00 p.m.
I have over 200 pictures. Just ask.
oestek
01-13-2013, 10:58 AM
Great color and a good looking car! We'd gladly throw our hats in the ring for the assembly job if someone wishes to buy this car and have it assembled for them!
classiccarcustoms
01-22-2013, 07:46 PM
Installed the LS1, 6-speed and new frame under the car over the weekend. Also installed the new Unitsteer rack and pinion.
I will be working on this car all week.
tommycomfort
01-23-2013, 04:53 AM
Excellent Chevelle! Good luck with the sale.
Tom
724tim
01-24-2013, 04:27 PM
Looking good , Good luck with the sale.
classiccarcustoms
01-26-2013, 04:57 PM
Installed the complete front grill with bezels, all powder coated, new lights. Installed new front bumper and marker light assemblies all plated.
Got new wheels and tires. Intro Twisted 18's with BFG G-force T/A KDW. Tail lights and bezels also installed.
shane38
01-26-2013, 06:57 PM
Great build!!!good luck
Curious what color that this or paint code thanks!!!
classiccarcustoms
02-22-2013, 08:28 AM
Thanks.
Current pictures and update.
I have installed the following:
New drives haft.
All new SS lower rocker stainless and wheel well chrome.
New rear bumper and powder coated brackets.
Ricks stainless steel gas tank with built in pump with all fuel lines and filter installed.
Powder coated battery mount in the trunk with new Optima Battery and cables all installed.
New door handles and lock set installed.
Coated headers and new Blue spark plug wires.
Inside of firewall is sound prof and black felt installed to clean look.
A/C and heater box is installed under the dash.
Powder coated brake and clutch pedals and custom under the dash mounting brackets and WilWood clutch and brake master cylinders installed.
Drive by wire gas pedal installed.
I will try to work on the car this weekend and get some new pictures and updates.
Price has gone up some with the new parts I have bought.
If you have any questions of need more pictures please call.
831-704-7331
May do part trade for a 68-69 Camaro (not stock)
MK69RSSS
02-23-2013, 01:09 AM
Nice
xxxturbo6
03-03-2013, 05:09 PM
Sent you a PM....
HotWhls
03-12-2013, 07:09 AM
Nice looking car very clean. The only thing I have for you is your wheels are on backwards. You have the left side on the right side. Those are directional wheels.
The Am1nal
04-03-2013, 09:05 AM
the wheels look better the way he has them on i think.
classiccarcustoms
04-26-2013, 09:22 PM
Up date:
Got my 66 running. Clutch and brake lines all custom done as well.
Price has increased. Interior and install glass and your done.
Racie
04-28-2013, 06:04 PM
Man a bump for one beautiful ride!!! I keep looking and drooling over this thing!!! Is that Jet Stream Blue? If it's Marina Blue thats the best looking Marina Blue Chevelle I have ever seen!!!!! Best of Luck with the sell...
texasdvldog
04-29-2013, 07:03 AM
what color is that?? Beutiful!
camaro73
05-01-2013, 05:26 PM
Some one buy this car. So I can stop looking at it. I don't think you will find a nicer looking Chevelle on the planet.
classiccarcustoms
05-02-2013, 05:04 PM
It is almost done now. I am having the interior done this week.
The color is base coat clear, PPG 1969 Lemans Blue.
I will put current pictures this weekend.
classiccarcustoms
05-02-2013, 05:05 PM
Bryan O
05-03-2013, 06:05 PM
Nice car!!
Regarding a possible trade, I assume you'd rather trade down and get cash rather than trade up and add cash to the deal?
classiccarcustoms
05-05-2013, 12:29 PM
Thanks.
I can trade up or down.
I get the 66 back from interior on Friday.
What will need to be finished at that time will be:
Install all new glass. I have.
Make and install 3 a/c lines and charge system.
Get an engine cover you like and install it.
Radio of your choice. I have ran all wires needed for a big stereo. I have bought and installed Focal rear speakers in package tray before it was covered in Suede.
Also made custom kick panels and installed speakers in them and had those also covered in Suede.
Price has increased and I have an offer on the table for the car turn key. Just don't know when i will have the time to get it there.
If someone buys it in the next day or so, they can pick there interior patterns.
Eric
831-704-7331
classiccarcustoms
05-05-2013, 12:33 PM
Here are a couple more pictures before interior.
classiccarcustoms
05-11-2013, 09:22 PM
Update:
5-11-2013
Just got my 66 Chevelle back from interior.
It runs and drives.
What is left to be done:
Install all the glass.
I have all new glass in the box and I also have all the original in great shape.
Install the stainless around the glass. I have all the stock.
Install a a/c condenser and a couple lines.
Radio.
Engine cover and new air filter. The one int he pictures was for mock up only.
Door panels are off to install the side glass.
Interior is complete with Suede and leather. Very nice.
classiccarcustoms
05-11-2013, 09:27 PM
Yes, the trunk was open on my 66 in the 5th picture. Body lines and gaps are great.
Yes, I will also sell my 65 SS frame off Pro Tour as well.
It can come with or with out a LS2- auto or a crate 350-350 or Muncie or roller.
I am taking my father in laws coupe to interior Monday and hope to have it on the road before his birthday at the end of June.
It is in the back ground in one of these pictures. Just need to find and couple things like door latches and window brackets and I should have his car done.
Eric
classiccarcustoms
05-21-2013, 07:24 PM
Update:
5-21-13
New front and rear glass installed. Rear is smoked.
New rear side glass installed and also smoked.
New felts and seals.
New air filter set up installed.
It is also 100% wired and everything works. (except a/c)
I will be working on wing windows and front side glass this week after work.
I will try to have better/current pictures this weekend.
classiccarcustoms
05-21-2013, 07:27 PM
I will trade up or down with cash. I also have 2 other car to add if needed.
65 SS frame off as well.
CHUCKIE
05-22-2013, 11:53 AM
Killer job!!
CornHusker4Life
05-22-2013, 12:35 PM
What is the new price, since more work has been completed? Nice car!!!!
Mudmony
05-25-2013, 03:13 PM
Just what I am looking for, pricing?...
Trevor @ Texas Speed
05-29-2013, 02:54 PM
as well!
cactuss4
05-30-2013, 09:28 PM
That is the right color, boy hood dream of a 66 in that specific color, although in my head it had stripes, but that's soo clean!!
w0w really nice.
classiccarcustoms
06-01-2013, 08:48 AM
Thanks.
The pictures today are from my phone, so I will try to get better ones tomorrow.
All the new smoked glass installed.
All new door seals, felts & rubbers.
All new interior installed.
I will have a video up on You Tube today of the car running.
What needs to be done as of right now:
1. Install stainless around front and back glass. I have.
2. Outer mirrors. I have L & R new in the box.
3. Raise the front end about 3/4-1" and corner weight and align the car.
4. Installed front seat belts. I installed 3 sets in the back before putting the rear seat in for the kid's.
5. Radio. I have custom front kick panels covered in Suede with 6.5" speakers installed, rear package tray has 2 Focal 6x9 speakers installed. I have ran all wires needed, from front to rear.
6. A/C condenser, buy one and install. Will also need 3 a/c lines made. I have all lines inside the car done and a billet a/c dryer in side fender well with switch.
7. Hook up E-brake.
8. Glove box latch.
I will try to work on the car Sunday and Monday. But I get my father in laws 34 coupe back from interior on Tuesday and then this one will be sitting for a while.
As the car sits right now price is $59,000.
If I get the car 100% turn key, it will be in the mid to low 70's.
Will trade up or down.
http://youtu.be/7ZaR0GxCGtg
classiccarcustoms
06-05-2013, 09:08 PM
Update:
Front windshield stainless is polished and installed.
Left & Right outer mirrors installed.
New steering wheel.
New laid back Hurst shifter with White 6 speed ball.
New Chevelle floor mats.
New custom sound processor with lap top programing and I-pod hook up custom fitted in the factory radio spot.
Bought a Be Cool Billet A/C condenser. Still have to install.
Car will get aligned and corn weigh tomorrow.
classiccarcustoms
06-05-2013, 09:10 PM
Also added Black Billet Lokar pedals.
classiccarcustoms
06-09-2013, 06:27 PM
She is 99% done.
Took her out on the road this weekend. Put about 100 miles on her.
Very
Left to be done.
E-brake.
Charge a/c.
cactuss4
06-18-2013, 08:43 AM
Just w0w, what a well done machine. Right color (it's the color of my friends 66 when I was just a boy). I think everything is done right on it. I started looking under my cushions for an extra $20K+ and remembered I'm not a hip hop/pop/rock star that could possible lose that much money and not notice it.
So if you win the powerball and want to make someone really happy, you know where I am!! Maybe you can cut the car in half and I can buy half? :) hahaha
Nice job, really well put together
Tory
Livermore, CA
jashearer
06-18-2013, 12:39 PM
So what is the price as she sits today?
I keep going back and forth between modern muscle like a 911turbo or a Z06, or good quality drivable old muscle... I just love this thing.
Jay
classiccarcustoms
06-18-2013, 08:43 PM
I have added a very nice stereo system with amps and custom box. I have about 200 miles on the car today.
Everything works except a/c and e-brake.
I have all the parts to finish the a/c.
The rear disc brakes have a built in E- brake assembly. I just need cables and a release handle. I was thinking of doing an electric kit off a push button.
I am looking to get $61,000. Or trades.
This car is build very well and handle like a dream. I got my 1 st speeding ticket in it Friday. Wife says it has to go. the car looks like ti is going fast just sitting there.
I will take better pictures and a driving video this weekend.
Eric
cactuss4
06-20-2013, 09:38 AM
Eric
Probably no interest in a 500-600hp Audi S4 and cash :)) Can't help you with speeding tickets, but the Cactus green is a bit less in your face, and while she is loud, probably not quite as loud as the Chevelle. Not as much rear seat room either :) hahaha
Really a well done build!!
Tory
classiccarcustoms
06-22-2013, 12:09 PM
Thanks for the offer. I will pass.
I took the car out this weekend and put about 110 miles on her. Stops people everywhere.
This car is ready for a new home.
Stereo system will rock you out of the car.
Looking for a wake board boat, house boat, in ground pool, Camaro or??
classiccarcustoms
06-27-2013, 06:47 AM
Ebay item # 181162731330
classiccarcustoms
07-01-2013, 07:37 PM
Almost made it on my father in laws coupe. Motor started smoking today and oil coming out header. Chevelle has to go.
I will be posting it on Ebay for a buy it now at 56k. as it sits today. If it doesn't sell in a couple days it will go to storage.
Eric
Jsudik
07-02-2013, 07:08 AM
My father has a couple of cars he is willing to part with.
1966 ss 396, numbers match, 325hp, 4 speed, bench seat, air comp is out of car, marina blue, vinal top black, black inside, dog dish hubs, and power assist steering.
78364783657836678367
And he also has an unrestored 1968 RS SS Camaro, numbers match, 4 speed California car, motor is fresh, All correct, smog pump, no power or air, 40,000 miles, drives perfect.
78368783697837078371
DandyDon
07-02-2013, 08:09 AM
What can you tell me about the Chevelle and Camaro? Prices? If you have a phone contact, that might avoid a lot of back and forth emails.
Dandy Don
Akron,OH
classiccarcustoms
07-12-2013, 07:00 PM
I drove my 66 on a 140 miles run today. Something came up and broke my power steering line.
Here is a chance for a great deal. 3 days only. Take the car, $52,000 as is. I have 513 miles on her since completed.
This pictures are today.
I need a small block 327-350 for my father in laws coupe. Will take some $ off for a ZZ4 or nice small block.
thanks
cactuss4
07-12-2013, 08:17 PM
Still one of the best looking chevelle's I have seen. I can't swing it. Just started talking to folks about selling my S4 and S6, but even then too much coin, worth it to someone, but I can't do it. But if I didn't have a kid and a wife, I would negotiate.. Wait I want it to enjoy with the family, sooo that's not quite true!!
I almost want to plan a trip just to see your stable, the 66, the 65, your fathers car etc. Just appear to be really neat cars, before it takes off with a new owner out of state!!! Would be neat to see a car that was done right, and so clean.
Good luck with the sale, i'm not stalking, really I'm not!!!
Tory
Livermore, CA
firstgencam
07-13-2013, 09:03 AM
How much is the Chevelle and camaro?
classiccarcustoms
07-15-2013, 08:31 AM
Local sale pending.
classiccarcustoms
07-17-2013, 02:01 PM
Sold.
TJ316
08-08-2013, 06:20 PM
Hello.....Please forward pictures to the car.
Thank you,
Tom
TJ316
08-08-2013, 06:35 PM
Please send me pictures......
Tom
603-493-5193
cactuss4
08-08-2013, 08:38 PM
3 posts, 2 of which are asking for pictures of an already sold vehicle, the other post asking for pictures of another vehicle. All threads of which have pictures, and quite a few..
Larry Callahan
09-01-2013, 05:15 PM
Car is sold. I'm closing the thread.
