MichaelLeeHearn
01-09-2013, 02:57 PM
The dashboard that come with my RCR40 is made from fiberglass. I am not planning on using the stock style gauge layout. Instead I am planning on using RacePaK IQ3 digital dash and a few other gauges from them also.
I am also going to be making a few other mods to the dash for the A/C system duct work and defroster vents. I also plan on removing the corners around the roll cage so I can make it to where I can remove the dash with the windshield and body on the car, in-case I need to work on the wiring or anything also.
So I can either cut-up the dash to modify it and use it as is or modify it and use it as a form to build a new one.
If I use the one supplied with the car as a form, I think it will be easier to make the changes I need to and make it look a lot better. Plus be able to lay out my switches everything better.Here a few pictures of the supplied dashboard, a few pics are of Right hand drive version, but are good pics of the gauge layout.69807698086980969810
