View Full Version : Narrowing a 67 Chevelle 10bolt -2" ? Possible?
lsxoo7
01-03-2013, 10:10 AM
Is it possible to narrow a 67 Chevelle 10 bolt -2 on either side and not have a interference issue with the stock Frame rail or have issues with the stock bracket locations ?
Looking to have a rear 10" rim with a 3.25 backspacing .
or is a minitub and chassis clearancing a must ?
Any info would be greatly appreciated
thanks !
01-03-2013, 06:30 PM
If those rims are worth it you could narrow it as long as you stay on the outer section of the tube...lower trailing arm bracket to the wheel. there is about 4" to play with. Narrow the tube 2" then get axles 2" narrowed from stock.
However with the rims going the other way you will run into sheetmetal problems.
lsxoo7
01-03-2013, 08:54 PM
Yeah looks like there is enough room .
-2 from either end and move the suspension bracket over .5" and looks like it should work .
Anyone else done this ?
01-04-2013, 10:53 PM
If you are up to it you can replace your lower trailing arm to axle tube brackets to lower the mounting holes.
