View Full Version : Chassis Works G-Bar w/9" 35 spline. Billet LCA's, splined sway bar billet links. New.
67 ls1 vert
12-30-2012, 09:22 PM
Chassis Works G-Bar w/9" 35 spline. Billet LCA's, splined sway bar billet links. New. 67-69 camaro (https://www.pro-touring.com/classifieds.php?mshow=listing&id=chassis-works-g-bar-w-9-35-spline-billet-lcas-splined-sway-bar-billet-links-new-67-69-camaro-4288&p%5Bmshow%5D=listing&p%5Bid%5D=chassis-works-g-bar-w-9-35-spline-billet-lcas-splined-sway-bar-billet-links-new-67-69-camaro-4288)
Chassis works 4 link (G-Bar). 67-69 F-body. All items are brand new. No longer have the car this was going into so now I am selling it for a loss. If you were thinking about a cool 4 link, this is the best parts you can get. Chassis Works 'G-Bar' coil over with billet end links option . The LCA's and splined sway bar option. The 9" center section cost $2000 alone. Aluminum Pro Pinion support For Large Competition 35 spline . 1350 yoke. 35 spline axles to handle the big HP engines with 4.11 gears. The G-bar comes pre welded to the 9" so I will not separate. The kit cost over $7000. Last Picture is a sample of the kit I have for sale. Mine has not been completely installed for pictures. The 3rd member never out of crate.
List Date: 12/31/2012
For more info, check out this listing in the Pro-Touring.com marketplace: Chassis Works G-Bar w/9" 35 spline. Billet LCA's, splined sway bar billet links. New. 67-69 camaro (https://www.pro-touring.com/classifieds.php?mshow=listing&id=chassis-works-g-bar-w-9-35-spline-billet-lcas-splined-sway-bar-billet-links-new-67-69-camaro-4288&p%5Bmshow%5D=listing&p%5Bid%5D=chassis-works-g-bar-w-9-35-spline-billet-lcas-splined-sway-bar-billet-links-new-67-69-camaro-4288)
On Sale For: $5000 + $250 Shipping
Retails for: $7700 | You Save $2700 | That's a 35% Discount!
https://static1.pt-content.com/images/noimg.gif (http://enthusify.com/protouring/listings/chassis-works-g-bar-w-9-35-spline-billet-lcas-splined-sway-bar-billet-links-new-67-69-camaro-4288/purchase)
https://static1.pt-content.com/images/pt/2012/12/Rcda3YWGb5FC2-1.jpg (https://www.pro-touring.com/classifieds.php?mshow=listing&id=chassis-works-g-bar-w-9-35-spline-billet-lcas-splined-sway-bar-billet-links-new-67-69-camaro-4288&p%5Bmshow%5D=listing&p%5Bid%5D=chassis-works-g-bar-w-9-35-spline-billet-lcas-splined-sway-bar-billet-links-new-67-69-camaro-4288)
https://static1.pt-content.com/images/pt/2012/12/aKcXQPZ7YNgJ2-1.jpg (https://www.pro-touring.com/classifieds.php?mshow=listing&id=chassis-works-g-bar-w-9-35-spline-billet-lcas-splined-sway-bar-billet-links-new-67-69-camaro-4288&p%5Bmshow%5D=listing&p%5Bid%5D=chassis-works-g-bar-w-9-35-spline-billet-lcas-splined-sway-bar-billet-links-new-67-69-camaro-4288)
https://static1.pt-content.com/images/pt/2012/12/YGtMWtxcNewF2-1.jpg (https://www.pro-touring.com/classifieds.php?mshow=listing&id=chassis-works-g-bar-w-9-35-spline-billet-lcas-splined-sway-bar-billet-links-new-67-69-camaro-4288&p%5Bmshow%5D=listing&p%5Bid%5D=chassis-works-g-bar-w-9-35-spline-billet-lcas-splined-sway-bar-billet-links-new-67-69-camaro-4288)
https://static1.pt-content.com/images/pt/2012/12/xfkhRfrvESaw2-1.jpg (https://www.pro-touring.com/classifieds.php?mshow=listing&id=chassis-works-g-bar-w-9-35-spline-billet-lcas-splined-sway-bar-billet-links-new-67-69-camaro-4288&p%5Bmshow%5D=listing&p%5Bid%5D=chassis-works-g-bar-w-9-35-spline-billet-lcas-splined-sway-bar-billet-links-new-67-69-camaro-4288)
sporter
12-30-2012, 10:39 PM
Nice set-up. What bolt pattern do the housing ends use, GM or Ford? Are the shocks adjustable and what are the spring rates? Which differential does it come with, TruTrac? Thanks!
ronniej
12-31-2012, 02:35 AM
What's the width?
67 ls1 vert
01-01-2013, 11:12 AM
Hey Sporter.. the bolt pattern is set up for running GM wheels.
The shocks are adjustable.
As for the spring rate... im not sure but think its 250lbs ? I will have to do some research.
The center section is a detroit locker. Frank ordered it for me a while back and Im pretty sure that what it is. I was going to build a car with over 1000 rwhp.
If you need anything else let me know.
Thanks.
67 ls1 vert
01-01-2013, 11:14 AM
RonnieJ...
The rear end is made to work in a Camaro or Nova with mini tubs.
55" This will allow you to use 335mm tires.
Thanks for asking.
sporter
01-01-2013, 01:05 PM
Sorry, I should have been clearer. Are the housing ends setup for Ford or GM brakes? My current Moser 9" rear has GM bolt pattern on the housings which lets me bolt 4th Gen F-body brakes to the rear. Thanks.
67 ls1 vert
01-01-2013, 09:08 PM
The brakes were set up for the big willwood 6 piston brakes, GM style. Hope this helps.
Thanks.
souljaboy9768
01-03-2013, 07:23 PM
Awesome setup, wish I had the cash!
67 ls1 vert
01-07-2013, 10:43 PM
Ttt
Biltx77
03-04-2013, 08:49 AM
Tried to reply to your post, your mailbox is full
