View Full Version : Custom Parts and Plumbing Coming..
Brian - JCG
12-28-2012, 10:09 AM
We here at JCG pride ourselves in being able to think outside the box and when we get into a snag we design and create something to make it work. We are always making parts for customs and are now going to start selling some of these. We make fittings for A/C, Fuel, Brakes, Oil, etc. Custom Made tanks for any application i.e. coolant, power steering, oil, fuel. So look for us to post up some different items as they become available on our store..
https://static1.pt-content.com/images/pt/2012/12/IMG_30031_zps76ccf7af-1.jpg
Rear Brake Distribution and Breather Block in Aluminum and Steel
https://static1.pt-content.com/images/pt/2012/12/IMG_30001_zps0944c9fc-1.jpg
https://static1.pt-content.com/images/pt/2012/12/IMG_29991_zpse0761ab7-1.jpg
astroracer
12-28-2012, 10:26 AM
Beautiful work! I have a question.
I am using a '95 Astro hydroboost on my van build and would like to replace the low pressure return barb that came stock on the unit. It has a 5/16-20 thread with an o-ring seal and is a straight fitting. I can't find anything to replace it with a 90 degree fitting. I can get photo's or model up a fitting if needed. What do you think?
Mark
Brian - JCG
12-28-2012, 12:22 PM
Mark
Yes, please get me a pic or two and we will see if we can help you out. Thanks
astroracer
12-29-2012, 05:27 PM
Thanks Brian! Here is a quick model and drawing of what I am looking for. The 5/16-24 thread is a typical -2 straight thread. and the larger -4 is a standard AN that I can use for a 90 degree fitting. Material can be steel or Stainless. The small thread I doubt would live very long in aluminum.
The fitting as I modeled it.
https://static1.pt-content.com/images/pt/2012/12/CUSTOMHYDROBOOSTRETURNFITTINGvi-1.jpg
And the drawing.
https://static1.pt-content.com/images/pt/2012/12/OMHYDROBOOSTRETURNFITTING_dwg1vi-1.jpg
Holler back if you need anything futher.
Thanks again.
Mark
Bowtie racing
01-27-2013, 12:48 PM
Stainless weld on fittings are just what i was looking for. Pm sent.
