View Full Version : Can I run Stock booster and master with c6 z06
97 z me go
12-25-2012, 08:27 PM
Im running kore3 rear disc set up with ebrake, and afx spindle up front. I have all c6 z06 caliper with stock rotors. Im doing 6.0 with TVS2300. This is on a 71 Nova.
My question is why can or cant i run the stock booster and master? This way i can run all the stock lines also. If not what would you suggest? Im beating my head against the wall as everyone does hydra boost or manual. The car is for fun i plan on driving it not sure im going to road race it.
Kyle
john31s
12-26-2012, 09:57 AM
If I'm not mistaken you would want to run a 11 inch booster and a C3 corvette master cylinder (15/16ths iirc). Just call Tobin at Kore3 to double check.
Randy67
12-26-2012, 12:03 PM
I believe you need to run a disc/disc master, not the stock disc/drum master. On my 67 El Camino, I used a 67-76 Corvette master cylinder and it hooked up to the stock lines. This was with C5 front brakes/LS1 rears. I would check with Tobin as well before buying anything.
