View Full Version : How to "prevent" vent windows from closing on the highway?
ertoys
08-08-2005, 05:40 AM
Is there an adjustment that I can tighten? or do I have to replace some parts that are worn out?
Happyfunballs
08-08-2005, 06:35 AM
Underneath (and attached to) of the vent window is a stud that has a nut and a spring on it. Tighten up the nut, and compress the spring a bit more and that SHOULD do the trick.
TonyL
08-08-2005, 06:36 AM
sanding the pivoting surface of the washers invloved with rough sandpaper will help too.
ertoys
08-08-2005, 06:43 AM
Thanks, I will try both of the suggestions above!
steemin
08-08-2005, 10:53 AM
The answer is understanding physics.
One simply could always drive in reverse.
The wind resistance would surely keep the vent window from closing.
Sorry I couldn't resist..
Good luck with the more practical solutions.
Scott
