View Full Version : Pro Tour 69 Charger Wheels/Tires Recommend
chickendeluxe
12-22-2012, 03:54 AM
Hi, First Post. Car has some chassis work complete.
I have to start building rear suspension so I have to decide soon!
Is there a benefit to Forged over Cast Wheels?
Would like to run staggered look. 19 or 20 rear, 18 front.
Thinking of an open style 20x12 with industrial look.
I have 29" of tire height possible and up to 15" cross section.
Will I have a better chance matching tire brands using rear 20"s?
Thanks, Chris
chickendeluxe
01-01-2013, 05:57 AM
I have scored 13 " 6 piston wilwood front and 12" 4 piston rear. What wheel size will be best with these. Im thinking of 18x8 front and 19 or 20x12 rear.
I like the Boze LateralG and Billet Spec SLG 23's.
jpgolf14
01-01-2013, 09:21 PM
Remember its not only the diameter that needs to fit, but also the caliper face to back of wheel spoke.
With that said, from a diameter point of view, certain 16's will fit a 13" rotor. Any 17" wheel should fit a 13" rotor.
chickendeluxe
01-02-2013, 01:25 AM
Great info. I will advise the calipers used when ordering with the wheel company.
JayR
01-04-2013, 12:30 PM
Diameter is all about personal taste and proportions but on a car that size, I wouldn't hesitate a second to fit it up with 19s and 20s. Let us know if we can build you a set.
Here's one we did a while back
https://static1.pt-content.com/images/pt/2013/01/95E70F94A11649FEBFDA21C7058026DC_3_zps64-1.jpg
https://static1.pt-content.com/images/pt/2013/01/95E70F94A11649FEBFDA21C7058026DC_1_zpsed-1.jpg
chickendeluxe
01-10-2013, 04:32 PM
I've decided on 345-30-19 Rear (Viper Tires) and 245-45-18 Front.
jason, I will check out your website again. Looking for something more industrial/vintage than your example.
Thanks, Chris
chickendeluxe
01-20-2013, 05:32 AM
The Boze Injected is becoming appealing, but pricey.
They are a manufacturer that offers various coatings and finishes.
I like the idea of a satin black lip with Pinstripe to mimick a taller sidewall.
3 piece also allows for flexible coatings on center.
I am getting closer to the desired style.
First to purchase the Unlawful 4 bar rear suspension.
Differential width to follow then wheel dimension.
to be continued....
chickendeluxe
01-20-2013, 06:07 AM
http://bozeforged.com/injected.html
slow02gt
01-22-2013, 03:32 PM
check out true forged wheels:)
chickendeluxe
01-28-2013, 08:46 AM
Injecteds with tires will happen. www.unlawfulracing.com rear suspension will make way for clearance with full tubs.... Progress.
chickendeluxe
02-11-2013, 07:22 AM
Will use the:
19x12 with 345/30/19 rear.
18x9 with 265/40/18 front.
chickendeluxe
04-16-2013, 08:14 AM
Wheels just got produced. There will be a red pinstripe on the black edge.
chickendeluxe
04-16-2013, 08:17 AM
pics
66DroptopD
04-16-2013, 11:41 AM
Wheels look nice!!
Im interested to see how they look with the tires mounted on em, i like your idea of going black to make the sidewall appear taller!
Keep the pics coming!
