sjaroslo
12-18-2012, 01:28 PM
I'm sure that this has been beat to death but a quick search here didn't exactly provide answers....
To remove the axles from a Ford 9" rear end, I believe that you remove the 4 nuts/bolts out at the wheel end (accessing them through the hole in the axle flange) and the axle slides right out--yes?
Second question is, with my rear end, it has zero miles on it, so do I have to replace the axle seal? In other words, do you have to replace the seal every time you service the axle, because it will likely be damaged by the axle removal? Or do people just recommend it because they are assuming that you're servicing a 75,000 mile rear end and since you've taken it apart this far, you should replace that consumable item?
It's funny the kinds of things that I'm scared of doing.... :-( But I really don't want to deal with the seal replacement if I don't have to. Thanks!
