    Results 1 to 5 of 5
      Dec 2010
      Fredericksburg, VA.
      Converting alternator from single wire to regulated?
      I have a new 140amp Powermaster 12si style single wire alternator on "Dust Off". It has been working fine but now I'm wondering what is needed to convert this alt to a regulated style. I assume I need to install an internal regulator or something along that line. I have wiring diagrams so I know how to connect it to the car but I'm curious if the alt can be converted.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Oct 2009
      Reno, NV.
      The powermaster I bought had both options, one wire or three wire. They had a black plastic cap over the regulator. You may want to check that first.
      Joe M
      '67 Firebird
      My build thread: https://www.pro-touring.com/showthre...irth&highlight=
      Dec 2010
      Fredericksburg, VA.
      I'll check that, my powermaster has a black plastic cap over the regulator as well.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      Southern Indiana
      Find local re-builder and simply have regulator swapped out. Part of the way those no wire alts work is with a "defective" regulator that has an incorrect internal shunt inside. I have seen some people pull the caps off but many will never turn off and run batteries down. You can also tear it down your self. Swap out regulator with a good one from napa store, use echlin branded ones. Reloading the brushes only require a paper clip or the red spout nozzle off a can of wd 40.
      no wire alternators "self excite" but are lousy at low speeds from my 25 yrs of mechanics experience.
      Lee Abel
      AFTERMARKET PERFORMANCE
      Dec 2010
      Fredericksburg, VA.
      Good, I was wondering if a simple regulator swap would do the trick. Replacing the regulator is not a big deal for me. I have noticed the lights dim down while setting at a traffic light at idle. I have also noticed the lights dim when the radiator fan switches on. From what I have read switching to a sensing alt will help this.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
