View Full Version : 1967 Chevelle Malibu PT Project -Las Vegas NV
MCMLXIX
12-11-2012, 06:36 AM
Well I'm not sure if I'm going to be able to finish the car. Life is kind of getting in the way.... Below are the highlights, check my build thread for pics and more details. The car comes with everything in the build except the motor. I have a little over $13k in major parts (not including the motor or the original purchase price of the car) and that doesn't include small things or the fab work to date. This started as a rust free California car. Has a clear Nevada title. Figure you get a discount on the parts and a free Chevelle for $13,000.... or $13k in parts for $9k and $4k for a rust free rolling Chevelle.. Package deal - ALL or NOTHING.. Either someone picks up one hell of a starting point or I finish it when I get the chance...
https://www.pro-touring.com/showthread.php?54071
Moser 12 bolt rear : NEW - never run
3.73 - Detroit Tru-Trac 33 spline Big bearing Ford ends with 02 Camaro disc brakes with e-brake
Aluminum driveshaft - Built with all new parts, 1350 u joints
LeMans fuel filler w/ Locking cap
Front Upper Arms - adjustable SPC Performance
Front Lower Arms - coilover SPC Performance
Currie Rear arms - Adjustable uppers / Johny Joint Lowers
LEE Mfg power steering box - NEW never run (Lee is the NASCAR box builder)
ATS AFX tall Spindles
C5 Brakes w/ braided stainless line
VariShocks adjustable coil overs on all 4 corders
NASCAR style splined rear sway bar from Speedway Engineering
Wilwood dual pedals
Ididit tilit column black
ISIS wiring system
LED tail lights
AFCO Radiator LSx 80252nls
Edelbrock Headers ceramic coated
T56 from 2002 Camaro SS
ZO6 flywheel / clutch kit (new GM)
Coys C-67 18x8
Dunlop 245/45/18
GTO power seats and rear seats
I have an extra flat hood and grill center. All molding included with a few extra odd pieces.
Remember, the car is in pieces... below is a before shot.... :twothumbs
68586
MCMLXIX
12-14-2012, 05:06 AM
I was asked about shipping...
I can bolt the front end back on the car and install the 5.3L block and T56. The rest of the parts should fit inside the car, except for the extra hood. The car is rolling but would you would have to grab the front wheel to steer it while pushing/loading the car.
I was also asked for some recent pics, so I'll try and post some after the weekend. The car is at a friends shop, about 45 minutes away. Some parts are at my house and others are at the shop.
jwcarguy
12-14-2012, 07:50 PM
Rich,
Sorry to hear that you have decided to sell your Chevelle
I remember seeing it at Tyler's shop and talking with you about it
Jeff
Reckn8
12-17-2012, 03:37 PM
Deleted.
MCMLXIX
12-20-2012, 07:47 AM
Here are some pictures of the parts and the Chevelle. We pulled the car out to take pics and it got rained on so the surface rust looks even worse. Nothing was primed because it was kept inside. The car really is a Fremont built California car.... The only patch it needed was under the passenger rear seat where water had collected over the years.... anyway, on to the pics ...
Z06 Clutch: 24255748 - Summit $279
Z06 Flywheel: 12571611 - Summit $275.00
https://static1.pt-content.com/images/pt/2012/12/20121220_065712_1_zpsa9f71849-1.jpg
https://static1.pt-content.com/images/pt/2012/12/20121220_065757_654_zpsfd342f32-1.jpg
Wilwood Pedals
https://static1.pt-content.com/images/pt/2012/12/20121220_065420_382_zps2b1c618a-1.jpg
AFCO aluminum LS swap radiator
https://static1.pt-content.com/images/pt/2012/12/20121220_065344_342_zps0291112f-1.jpg
Spare Grille center
Original dash, no cracks
New black package tray
https://static1.pt-content.com/images/pt/2012/12/20121220_070344_946_zps4a10962d-1.jpg
Original 67 A/C Dash (I have a 66 non AC dash bolted in place right now)
https://static1.pt-content.com/images/pt/2012/12/20121220_065323_747_zps7fd33704-1.jpg
And the car as it sits... needs the tunnel finished for to fit the T56 and nees the trunk floor to be raised. (no rust in the trunk)
I have the factory bumbers and a spare repo rear bumper. There is a metal bulkhead between the trunk and rear seat. Shock mounts are double shear on upper and lower. ALuminum diff cover with preload capability.
https://static1.pt-content.com/images/pt/2012/12/20121216_113916_240_zpsfdb1e467-1.jpg
https://static1.pt-content.com/images/pt/2012/12/20121216_113940_715_zps75083aa3-1.jpg
https://static1.pt-content.com/images/pt/2012/12/20121216_114018_429_zpsada2b8cd-1.jpg
https://static1.pt-content.com/images/pt/2012/12/20121216_113827_282_zpsb202826b-1.jpg
https://static1.pt-content.com/images/pt/2012/12/20121216_113823_228_zpsbb0feed5-1.jpg
MCMLXIX
12-20-2012, 07:50 AM
The ISIS system comes with the programming module so you dont have to send it back to make changes or if you add features. It also has two key fobs that allow you to control the system from outside the car....
CHAZMO1986
12-20-2012, 06:02 PM
I want this sooo bad i can taste it!!!!! Ive got my fingers crossed that it lasts until the end of january, Ive Gotta get rid of my car first,
MCMLXIX
12-20-2012, 06:27 PM
Well I'm not in a hurry to sell and I'm pretty firm on the price.... Plus I dont think anyone is going to make a major purchase during the holidays... so you may be in luck...
CHAZMO1986
12-20-2012, 06:39 PM
Good deal! I feel that the price is more than Fair, Ive been lookin for a 67 for years and found plenty of rough projects for damn near the same money, ill keep in touch
MCMLXIX
01-16-2013, 08:58 PM
Mid month bump... I'm a little more motivated as I would like to buy some additional parts for my other project that I would like to have....
also included is:
NEW center link
NEW Howe lower ball joints
Moog inner and outer tie rod ends and idler arm
Billet tie rod adjusters
MCMLXIX
02-11-2013, 12:31 PM
here is the front upper shock mount ...
71191
71192
MCMLXIX
02-11-2013, 01:23 PM
Here is a shot of the frame bracing.... plated the frame then added the tubing. Trans mount in the pic is not the final mount design...
71196
subtlez28
02-11-2013, 08:05 PM
I honestly do not understand why this car is still for sale. If I had not just picked up a kit car project I would have likely snatched it up. I did try to talk my dad into it, he is a huge 66 fan (his high school ride).
Good luck w the sale. I know how it is to get rid of a stalled project...
MCMLXIX
02-11-2013, 08:23 PM
I have someone coming to look at it next Tuesday. This is the only place I advertised it. I'm not in a hurry to sell but i may start pushing as the weather gets warmer. I have my high school Camaro to finish and I'm working on a 72 K5 Blazer with an LSx swap.
JaySB
02-23-2013, 12:48 PM
Did this end up selling?
classiccarcustoms
03-18-2013, 07:48 AM
Still for sale?
MCMLXIX
03-18-2013, 08:06 AM
I am waiting to hear back from one other interested party, but there has been no agreement at his time.
classiccarcustoms
03-19-2013, 05:58 PM
Please call me 831-704-7331
MCMLXIX
04-08-2013, 01:18 PM
Bump to the top. No one has followed through so the Chevelle is still available.
badream
04-19-2013, 06:44 AM
Do you still hav the Chevelle for sale? Call or text metat 319.541.7914. Thanks Alex.
classiccarcustoms
04-20-2013, 02:07 PM
Rich,
Lost your #. Please call me at 831-704-7331
Eric
MCMLXIX
04-25-2013, 01:38 PM
Sold Pending Funds...
BLWN1
06-06-2013, 05:59 AM
Funds pended?
MCMLXIX
06-06-2013, 08:41 AM
Sold and Shipped.
SShep71
06-06-2013, 09:03 AM
You pended the f**k out of those funds!!
