View Full Version : where to get 1" lowering blocks and u bolts
jaycoy65
12-10-2012, 07:23 AM
i have 1.5" rear drop leafs on my 68 camaro now and i want it just alittle lower so i want to go woth a 1" block.. any suggestions where to get them and also what size u bolts ill need and where to get them also
Rick Dorion
12-10-2012, 08:09 AM
When I put 1" lowering blocks on my 68, I got them from Speedway Motors. At the time, I got rid of the T-bolts and used U-bolts from Hotchkis, I believe.
Thephranc
12-10-2012, 08:36 AM
Speedway has them for sure.
jaycoy65
12-10-2012, 08:38 AM
whats the difference between u bolt and t bolt? wouldnt i already have u bolts on my rear leafs stock? will i need longer ones with the blocks? i bought a set of hotchkis rear leafs used from a friend but its just the leafs was gonna use my old harware and add the blocks
hotrodneb
12-10-2012, 02:59 PM
Advance and O'Reilly....prolly Autozone too.....take your old U-bolt in and they can match it for a longer one
John McIntire
12-10-2012, 06:02 PM
Jaycoy, I have a question for you, are you running the rubber isolater pad on top of the spring between the leaf spring and mount on the axle?
I am going through this same thing now. I did the Hotchkis rear leafs with a 1.5 inch drop and think it can come down a bit more.
I bought both a 1 inch spacer and a 1.5 inch spacer from Jegs made by Afco. Afco has longer 9.5 inch u bolts.
I have yet to try them out, but believe it will give me the result I'm looking for.
I'm also am kicking around the idea that if the 1.5 inch block works well, should I just get the 3 inch lowering springs? I'm not a hardcore auto crosser, so the blocks will probably do, and also if the springs sag over time I guess I could just remove the block and raise the car up a bit.
SR71
12-10-2012, 07:49 PM
as previously mentioned, you can buy the block KIT at the usually suspects.....advance, autozone, o'reilly, ect. the kit comes with u-bolts. I think I paid about $30 for my kit.
jaycoy65
12-12-2012, 02:17 PM
i just purchased the 1.5 afco blocks and 10" u bolts.. i havent installed the leafs on my car yet.. i just got them used off a friend of mine.. so ill let u know how it turns out after i get them on
Rod
12-12-2012, 02:32 PM
do not run the isolaters if youre running lowering blocks, the isolators allow the rearend to wobble in all directions
John McIntire
12-12-2012, 06:06 PM
Thanks Rod. That was my concern. It seemed like too much stuff sandwiched in there that had the possibilty to move around. I've heard that the removal of the isolater pads will transmit more noise and vibrations to the interior, but a lot of guys have chimed in and said thats not true.
