View Full Version : rpm matching for cam and intake?
darksider1911
12-08-2012, 10:17 AM
ok so Im planning adding a performer rpm intake and a 650cfm edelbrock carb on to my olds 350. It has a ol4b eddy intake on it already with a 600 cfm carb eddy as well but I want to increase the power this thing puts out. so my question is with the rpm intake it says its good for power from 1,500-6,500 and the cam I want to install is a 275DEH @ Duration 275/282, Lift .476/.508, good for power from 1,500-5,800. so what Im wondering if this set up will work together. the trans is a th350 with a stage 2 shift kit not sure of the torque converter. the rear gears are the stock 3.08, and it has an MSD 6al ignition box but only has a points dizzy for now. I really would like to make this think a torque monster that's why I'm staying with a 650 carb instead of going 750. any help with helping me out on this combo would be great. thanks
darksider1911
12-08-2012, 07:53 PM
Bumb. Any ideas anyone?
sam 74
12-08-2012, 10:51 PM
that should work fine, the stock converter should work with that setup as well, but you'd benifit from a little more stall speed. what you'll need to worry about are your springs and clearences. i can't remember all the specifics off hand at the moment but i think you may have some problems with .508 lift on a stock head.
TheJDMan
12-09-2012, 07:14 AM
IMO, you would be better off loosing the 3.08 ring and pinion and switching to say a 3.55 or 3.73 if you really want to wake up the performance.
darksider1911
12-09-2012, 08:00 AM
ya as far as the valve springs come with the cam kit im looking at. as far as the rear gears I have full intentions of changing them out I was thinking about going with 3.42s just to keep a little highway driving if needed. as far as the head clearance if I remember right the stock rocker arms are 1.6.
