View Full Version : TBW question
MichaelLeeHearn
12-06-2012, 06:22 AM
I am looking at AP racing pedal assembly for my next build. They have an option for Throttle by wire set-up, with one of there floor mounted assemblies (CPP5516-6CD) is the part number.
With both factory or aftermarket ECU's can you program them to work with different sensors for this as the pedal assembly comes with its own sensor. I have the specs for the sensor with the Tech drawings from AP racing. So would I be able to program this info into the ECU to make it work.
I am still making my mind up between two different builds and the engine choice for those.
One choice is an LS7 build and the other is a 5.4L Mod motor build, if this helps.
