View Full Version : Any 2nd Gen Camaros with 3" rear drop on 18" Rim?
Gasman303
12-03-2012, 08:19 PM
I'm considering going with DSE 3" rear leaf spring on the rear of my 71 Camaro? I'm unsure wether to go with 18x9.5 in the rear or 20x9?!! It is NOT Mini-tubed just bone stock for Now. My worries is that 20" rims will rub because they'll be too tall. I already have a Heids front upper and lower A arms along with Qa1 coil overs it's going to be a street driving machine!
V8240Z
12-03-2012, 10:51 PM
I have the PTFB 3" lower leafs in mine with 18 x 9.5 and a 275/35/18 tire and there is not a clearance issue at all. I also screwed up and added a 1 inch lowering block, it's too low but still no tire rubbing. Check out Customworks Performance, Keith offers delrin shackle bushings that will help with lateral shift also.
V8240Z
12-03-2012, 11:17 PM
This is it with QA1 coil overs in the front and the rear blocks still in.
https://static1.pt-content.com/images/pt/2012/12/48A115CC8B294D9B90BAA71AEA57706876470000-1.jpg
Gasman303
12-04-2012, 06:25 AM
Thanks for the lead, I will give them a look and see what they offer! Nice Ride that's the stance I am looking for!
damannhw
12-04-2012, 09:58 AM
Not a Camaro, but I'm running DSE 3" drop leafs with a 18X10 rear and a 285/40/18 tire. I had to roll the lips and flatten the seabelt hump, but no rubs now.
6833068331
Gasman303
12-04-2012, 05:54 PM
That's one Dope Car you have daman! Wow, I can believe you get a 10" tucked under there without a mini tub? Looks Good, thanks
