Results 1 to 20 of 26
12-02-2012 #1
- Join Date
- Dec 2006
- Posts
- 90
Chevelle with custom 67 corvette dash
This week I started undertaking a dash project on my 67 PT chevelle. I actually have 2 '67 projects, so some of the pictures I will share depict the other car. Handy to have another car for mock up!
First, I just used some 1/4" hardboard that I had in the attic of my shop which was left over from when the shop was added. You can buy the hardboard at just about any major hardware/lumber store.
I started with a 12" wide piece and I used the lower windshield molding to trace the profile of the dash cowl area. To do this you have to have the stock dash panel removed. I chose to cut the spotwelds out from underneath in case I ever needed to put the dash back to original.
Then, I placed a mid 60's corvette dash pad at about the right position and I traced around the back of the pad. This gave me the area to cut out.
12-02-2012 #2
- Join Date
- Dec 2006
- Posts
- 90
Here are some more pictures. Note from the previous pictures that the lower lip for the windshield is missing. This is my other car that needs the new lower windshield lip... you do not need to cut this out to do this. I will show my other car in later pictures.
Next, I started fabbing up the center piece which helped support the dash up better.
Since the chevelle is wider than the '67 corvette, I have a bigger space to fill.
Here are some first mock ups.
12-02-2012 #3
- Join Date
- Dec 2006
- Posts
- 90
My intention is to fabricate the dash structure out of 20 ga steel. I am going to try and lay the majority out onto a flat sheet of steel and then I can bend the center section down to the tunnel and I can bend the sides down and under to attach to the factory dash brackets.
My inspiration comes from the prodigy camaro. I believe he used a stock fiberglass dash to start. I considered doing this, but I couldn't find a dash housing for under $500 and then I was going to have to modify everything on it.
Here are the gauges I will be using. I already have all the harnesses built, just waiting for a bezel and a permanent home.
12-02-2012 #4
