View Full Version : budget rear disc brakes??
72'Monte
11-29-2012, 12:20 AM
i have a 12 bolt rear under my 72'monte carlo and was wondering if i could add disc brakes from another gm car?i go to the junkyards alot.i see alot of camaros with disc brakes.
analyte
11-29-2012, 06:14 PM
The F-car LS1 brakes are an easy conversion as are the C5/C6 Corvette brakes. Either choice will provide 12in disc's that will really make a difference if you also had the corresponding disc's to the front. Tobin at Kore3 has the brackets needed to help pull off the conversion.
Kerry
instro84
gm car rears should work fine, i used ones from a Cadillac on my 69 bird and i have ones from a 02 z28 on my current regal
11-29-2012, 07:34 PM
anything from 78-2002 is good if you can get cheap. 96-2002 are better just do to a reliable parking brake.
Daren
11-29-2012, 08:07 PM
I know 4th gen F-body rear disks will work with a 10 bolt GM rear. You'd need two lefts or two rights to pull it off. The 3rd gen stuff just doesn't have the braking power to warrant use. Don't even look at 2nd gens.
If you come across an IROC-Z, nab the steering box whether you need it or not. It's quick ratio with extra firm valving. Lincoln mark 8s, last gen T-birds and cougars have a great electric fan too.
These are all cheap buys with a pretty high demand amongst restomodders.
72'Monte
11-29-2012, 08:41 PM
thanks,i well grab all those parts.i plan to go with a big brake upgrade on the front.
72'Monte
11-29-2012, 09:03 PM
what should i pull off the ls1 camaro rear disc brakes to convert my car to rear disc brakes.
11-29-2012, 11:19 PM
Pull the backing plates/parking brake assembly, rotors, calipers, pad cage, hardware parking brake handle and parking brake cables.
You are going to have to pop the diff cover off the diff and pull the pin to get the c clips off of the axles.
Daren
11-29-2012, 11:23 PM
I don't know myself. Perhaps someone more knowledgeable can chime in. My understanding is that 4th gens are a bit screwy in the rear and two lefts or rights will be needed to swap to a 2nd gen. A monte? No idea.
Montes are cool cars. I'm looking for one to do a chevelle SS meets personal luxury coupe build when I free up some projects. Fell in love with them when I saw F&F Tokyo Drift.
72'Monte
11-30-2012, 01:21 AM
thanks.i also found a blazer with rear disc brakes.
72'Monte
11-30-2012, 01:43 AM
the camaro is a 5 on5 bolt pattern.what do i do for rotors?
dipren443
11-30-2012, 06:36 AM
The camaro is most definitely not 5x5. I have the exact same brakes and can assure you my 5x4.75" wheels fit on stock rotors.
72'Monte
11-30-2012, 09:26 AM
thanks,my neighbor said the camaro was 5x5.i should of know he was wrong.
5spd540
12-07-2012, 01:21 PM
I have rear disc on my 73 camaro from a 98 camaro
72'Monte
12-07-2012, 02:21 PM
thanks i'am going to do the same.
5spd540
12-07-2012, 03:27 PM
It is a good set up. I have drilled and slotted rotors on mine
72'Monte
12-07-2012, 03:34 PM
i was going to upgrade the rotors also.is the calipers single or duel piston?
5spd540
12-07-2012, 03:40 PM
Mine are singles
5spd540
I have 12in front and rear disc on my car
72'Monte
12-07-2012, 03:47 PM
i seen a kit for the front comes with 12'cross drill and slotted rotors and duel piston calipers.also comes with 2' drop spindles for less then $600
5spd540
12-07-2012, 03:48 PM
Thats cheap what kind of kit is it
72'Monte
12-07-2012, 04:24 PM
i want this kit.http://www.classicperform.com/Store2/Brakes/6472SWBK-D12-WWRD.htm
5spd540
12-07-2012, 04:28 PM
Oh I thought you ment front and rear
72'Monte
12-07-2012, 04:37 PM
i wish.
5spd540
12-07-2012, 04:44 PM
Me too
72'Monte
12-07-2012, 05:59 PM
i well beef up the front brake since they do more of braking.
5spd540
12-08-2012, 12:49 AM
I put 2piston calipers on the front of mine
72'Monte
12-08-2012, 10:52 AM
that's what i want for mine.
5spd540
12-08-2012, 01:05 PM
I have the d52 wilwoods
72'Monte
12-08-2012, 03:05 PM
any mods to get them on?
jlcustomz
12-08-2012, 05:59 PM
Doesn't sound bad at all for drop spindles & everything if it's around$600. Might check into for my g-body Since I will need drop spindles & brakes.
5spd540
12-08-2012, 06:14 PM
No direct fit
ARAD RS
12-08-2012, 10:48 PM
Do you have factory Drum/Drum or Disc/Drum brakes?
Factory 14" or 15" wheels or other?
Power steering or manual?
I believe you need at least 16" wheels to make this brake project start to fit.
You will also have to address your master cylinder and so on.
If you do go with the 4th Gen F body disc brake setup, get everything for the rear including the parking brake cables, and the calipers from the front if they are reusable. If not, you could use them as cores for over the shelf new calipers.
I'm thinking from what I have seen in the past this portion should set you back around $125.00ish depending on the condition of the braking hardware.
There will be additional hardware from various vendors that will need purchasing to make it all work out in the end.
And as stated before, It might be of interest to grab a Iroc Camaro steering box or sort.
FWIW i have a few left over components available from my 4th Gen F body to 1st Gen F-body disc brake upgrade if interested.
These threads from over at Team Camaro should be helpful before you start getting too crazy with your project.
It never ends once you start with the upgrades.
http://www.camaros.net/forums/showthread.php?t=161383
http://www.camaros.net/forums/showthread.php?t=103139&highlight=disc+brakes
http://www.camaros.net/forums/showthread.php?t=197446
5spd540
12-09-2012, 12:51 AM
If you have 15in wheels you can use 98-02 s-10 rear brakes and keep 15in wheels
32deucecoupe
12-09-2012, 10:05 AM
i am looking to buy a takeout 1999 camaro ss complete rearend with disc brakes, any reason not to use the entire unit in my 68 camaro? $80 complete..
72'Monte
12-09-2012, 10:50 AM
it might be a weak 7.5 ring gear 10 bolt.i blow one in a monte ss with a mild 350.
5spd540
12-09-2012, 11:32 AM
The 4th gen rear is very weak
badazz81z28
12-09-2012, 02:19 PM
The rear disc on my 1978 Camaro are from a 79-81 Trans Am. I don't have any complaints about them and all the parts are off the shelf items. I would invest more in the front brakes than the rear.
My set-up probably ran me close to $500 shopping at Rock-Auto, but I bought a new booster, MC, Prop valve, rear brake cables, levers, calipers, rotor, hawk pads etc... If you found a donor and used the old parts...could be done for $100 or less. To do it right, your going to spend some money no matter which way you go.
The rotors are 11"
5spd540
12-09-2012, 02:41 PM
I have 350.00 in my rears and about 900.00 in my fronts that is not bad for drilled and slotted rotors and 12in disc
MonzaRacer
12-09-2012, 05:36 PM
S10 is a bolt on and parts are readily available. and Corvette rotors slide over the parking brakes too.
Rod
12-09-2012, 06:50 PM
I used this kit on the rear with drilled and slotted
http://www.getdiscbrakes.com/afxrd05
and I used this kit front from CPP (http://www.ebay.com/itm/1967-1968-1969-CAMARO-13-BIG-DISC-BRAKE-KIT-NO-MACHINING-REQUIRED-BOLT-/250955458212?pt=Vintage_Car_Truck_Parts_Accessorie s&vxp=mtr&hash=item3a6e1c66a4)
and I used this power booster/ prop valve setup from the right stuff (http://www.getdiscbrakes.com/g10030572) but you need to call when ordering this setup and have them send you the Disc/Disc prop valve
I used the pads that came with each kit and it worked well, but I switched to Raybestos pro grade ceramic later and there much better
5spd540
12-10-2012, 12:49 AM
Those are cheap kits. How do they perform
Rod
12-10-2012, 10:12 PM
It all has preformed really well, Guess you have never followed my thread, it performed like this in November
goodguys Scottsdale November 2012 street machine class
Bam
https://static1.pt-content.com/images/pt/2012/12/1211phr070oPHRstreetmachineautocrossJPG-1.jpg
Bam Bam - WINNER
https://static1.pt-content.com/images/pt/2012/12/1211phr177oPHRstreetmachineautocrossJPG-1.jpg
Goodguys Del Mar November 2012 Pro Class!
https://static1.pt-content.com/images/pt/2012/11/IMG_2653-1.jpg
end of year events
https://static1.pt-content.com/images/pt/2012/11/1aa1-1.jpg
72'Monte
12-10-2012, 10:29 PM
cool 68'camaro.
5spd540
12-11-2012, 12:49 AM
No I just started getting on this site regular a lot to see. Nice car for a 1st gen
HELLCAMINO
12-18-2012, 03:24 AM
Front and rear LS1 98-02 Discs on my 72 Elco.
CodexGigas
12-19-2012, 02:35 AM
http://www.summitracing.com/parts/rsd-afxds78
How about these? I got Them
austinbelair
08-08-2024, 06:12 PM
So on the 98-02 rear disc stuff. Do I need 2 driver or 2 pass side setups? I keep reading conflicting info
dhutton
08-09-2024, 03:15 AM
It’s going to depend on whether you have staggered shocks or not iirc.
austinbelair
08-09-2024, 08:44 AM
Oh I thought all fbodies had staggered but yep, my 78 is staggered
dhutton
08-10-2024, 12:06 PM
My recommendation is go with Tobin at Kore3. Great value and quality. He knows his stuff too.
Kore3.com
Don
cdrod
08-13-2024, 07:46 PM
If you want to DIY your own rear disc conversion; I put rear discs on my '72 442 convertible project from a 2001 2WD Chevy Blazer. I needed a 1/4" spacer to center the caliper over the rotor, and 1/2" split donut bearing spacer to make up the difference in thickness of the drum backing plate versus the thicker Blazer backing plate. This was needed because the stock Olds 10-bolt uses bolt-in axles. I also installed a Lokar style parking brake cable system to have a functional parking brake. Here's some pics.
Rodney
214424
214425
214426
