CapSS92
11-21-2012, 07:42 AM
Hi all,
I have a question for those of you using airbags. What pressure do you normally run in your front and rear bags? I am using a Cool Ride setup on my 65 Chevelle with an LT1. When I had airride on my 92 Caprice I used to run about 90-100 PSI. The Chevelle weighs about 1000lbs less and when I run 90 PSI on it it looks like a 4x4. Good ride height is at about 70 PSI but I am riding the fence as to whether to install 2" lowering spindles. My concern is that it will sit too low and then I'm gonna have to run high pressures to get it to lift enough. I'm still playing around with different air pressures to try to determine the best ride feel but I was curious as to what everyone else uses. Thanks.
Alex
Alex
