View Full Version : Using two different types of brake calipers ?
L_O_O_M
11-14-2012, 05:53 AM
Hi all
I was wondering if it would be possible to use to different types of brake calipers on a car.What I would like to do is make a custom semi trailing arm suspension setup for a car but the the spindles I am going to be using in the rear of the car is from a different car.So can some one please enplane to me about brake booster size....etc and if you think something like this can work?
XLexusTech
11-14-2012, 07:24 AM
Well... the number of pistons and thier diameter has to be aligned... as that directly correlated to pressure... other then that I see kbnow issue with it...
In Fact Rifht now I am looking at using C6 6 piston fronts and Lexus floating rears... :-)
L_O_O_M
11-14-2012, 10:11 AM
Hi XLexusTech
Can you please explane more?
This sounds interesting,do you have a post?
XLexusTech
11-14-2012, 11:36 AM
pressure = Force/Area #pistons and diameter of them will make up your area.
here is a decent link (and embedded links) to get you started http://sports.racer.net/brake_bias.htm
L_O_O_M
11-15-2012, 03:21 AM
Thanks a million man.
