View Full Version : fuel tank breaths when I remove gas cap
rrelco
11-12-2012, 09:15 PM
I just finished my fuel injection and in the instructions it states that I must use a VENTED cap, I have been using a cap that says vented and anti-serg but still makes noise when I remove it.
the tank is a stock looking tank but with baffles.
the car wont run when the take has the pressure what should i do?
Chris71RS
11-12-2012, 10:04 PM
Check out this thread for a better vent https://www.pro-touring.com/showthread.php?87832-II-Much-Fabrication-Fuel-Vent-installations&highlight=gas+tank+vent
Mr Nick
11-13-2012, 04:41 AM
It's not pressure in your tank, it's vacuum from the fuel leaving the tank and air not properly taking it's place.
Is your vented cap new?
parsonsj
11-13-2012, 05:30 AM
Thanks Chris. Or you can have a look here:
http://blog.iimuchfabrication.com/?p=297
https://static1.pt-content.com/images/pt/2012/09/trunkoutsideview-1.jpg
rrelco
11-13-2012, 12:30 PM
Nick the cap says vented and i can blow through it as well as draw air through. II much fab is a little pricey so i will try to add a filter as a breather on the tank
Mike Norris
11-14-2012, 04:53 PM
In the end the II Much piece will end up not being that expensive as there are a lot of inexpensive fixes you can go though before finding what works properly. Especially if you plan on using the car for spirited and/or aggressive driving.
Mike Norris
rrelco
12-02-2012, 09:01 AM
installed the II much fuel vent system and it worked like they said no more pressure in my tank. thanks John
parsonsj
12-03-2012, 06:55 AM
Awesome to hear! Any photos of the installation?
