View Full Version : 1970 Camaro wheel and tire size help.
rsss2nvy
11-07-2012, 05:35 AM
I have a 70 camaro that is NOT mini tubbed and won't be. I just ordered Ride Tech's level 2 coil over system for the front and rear. I would like to run 18" wheels in the front and 19" in the rear. I am pretty sure I can do a 19x10 in the rear. Not sure what OI can do in the front. Has anyone run a 285/35/19 in the back. What rim width in the front should I run and tire size. Any Ideas on the offsets. I would love for this to be a weekend car and get into auto cross, so I want to have some clearance so no rubbing. Please help........
k7king
11-13-2012, 10:27 AM
Front 18X10 6 1/4 bs 275/35/18 tires
Rear 18X10 5 3/4 bs 275/40/18 tires
thats with wilwood front brakes on stock spindle and stock rearend
I run my car low
k7king
11-13-2012, 10:28 AM
I run my car low
https://www.pro-touring.com/showthread.php?92991-Project-Rellik&highlight=
Formula43wheel
11-13-2012, 02:33 PM
Typically a 8.0X18 w/ a 245 and a 9.5X19 w/ a 275 tire. With a DSE mini tub you can fit a 12" rear and w/ the DSE front sub frame a 10.0" front fits. I don't believe the coil over system alone with create additional wheel width clearance.
Hope this helps!
Bill71
11-13-2012, 05:57 PM
I run my car low
Do you have any pics with the 18x10's on the car? I am trying to do the same and I can't seem to figure out the right backspace.
k7king
11-14-2012, 04:10 AM
click on the link
rsss2nvy
11-23-2012, 06:24 PM
Thanks for all the help.
SLO_Z28
11-25-2012, 07:03 PM
285 is very small for a 10 inch wheel. 315's on 10 inch wheel will fit no problem in the back, and 285's up front are no issue either, stock subframe. I have stock frame and sheetmetal and I have the equivalent of a 295 p-metric tire all around on 17x9.5's,
https://static1.pt-content.com/images/pt/2012/06/110-1.jpg
https://static1.pt-content.com/images/pt/2012/11/111-1.jpg
