View Full Version : Early Stages 67 Camaro
Brian-Blade
08-03-2005, 09:33 AM
Been lurking on here getting some ideas
Plan is :
lowered suspension springs all the way around
all new bushings & ball joints
4 wheel disc brakes
17" rims & tires all the way around
sway bars front & rear
Going to reinstall interior & then paint car flat black & drive for a little while to save for paint job
Have replaced so far :
front floor pans
upper cowl panel & dash panel
lower outer cowls
I have all new sheet metal for front clip & 2 brand new doors
Need to replace both rear quaters & maybe rear tail section
here is link to pics
http://pg.photos.yahoo.com/ph/brian120444060/album?.dir=5e80&.src=ph&store=&prodid=&.done=http%3a//pg.photos.yahoo.com/ph/brian120444060/my_photos
F70t/a
08-03-2005, 10:11 AM
Cool camaro, Your plans sound great!!! Welcome :headbang:
Brian-Blade
11-07-2005, 07:59 AM
Got the underside I sprayed in POR15 Sat.
Got it off the rotisserie , making underbody roller mounts to install 1/4panels & tail panels
I am going to list rotisserie for sale here in next couple of days
pics:
http://pg.photos.yahoo.com/ph/brian120444060/album?.dir=c78f
Brian-Blade
11-10-2005, 05:07 PM
Got the floor painted tonight
going to sand blast front cowl this weekend & paint
Brian-Blade
11-16-2005, 06:08 AM
Got the cowl blasted & painted Sat. & then installed top dash
Brian-Blade
11-16-2005, 06:10 AM
Been working on 1/4 panels , outer wheelwells & tail panel
Did some rough cuts , checking everything out for finish cutting
Brian-Blade
12-28-2005, 05:55 PM
Finally got 1/4's welded on , Holy christ what alot of work mostly all kinds of prep work. I sanded & painted all inside of body & new panels ,weld thru primer in all weld areas , undercoating on all other surfaces.Welded everything then did some grinding tonight . I am hoping soon to order a-arms suspension components & 4 wheel disk brake setup soon & get it rolling again
Check pic link (http://pg.photos.yahoo.com/ph/brian120444060/album?.dir=/5e80&.src=ph&.tok=ph_leKEBRVfXafGR)
Brian-Blade
01-20-2006, 06:39 AM
Been a little while since updates
1/4s are on & welded still need finishing work done
Motor , Rear Axle & motor painted & ready ..Still up in the air on tranny
I have Auto & manual just have to decide which is best for right now
I would like to get it on the road this spring & then rebuild running gear next winter
Got subframe in rough position last night
BMR A-arms arrived
QA1 coil overs arrived
Hotchkis rear leaf spring loweing kit arrived
CE soild body mounts
Stock size 4 wheel disk brakes (waiting for rear to arrive) running 15" rally wheels for now
Running out of money for now I am going to get wheels back on & work on finishing body work
PICShttp://pg.photos.yahoo.com/ph/brian120444060/album?.dir=5e80&.src=ph&store=&prodid=&.done=http%3a//pg.photos.yahoo.com/ph/brian120444060/my_photos
Steve1968LS2
01-20-2006, 07:32 AM
Sounds like a nice project.. remember, sometimes you don't need a rear sway bar if you use aftermarket (stiffer) leaf springs :)
Just take your time with your project and thanks for the update pics!
srh3trinity
01-20-2006, 01:53 PM
Looks like a great project and I love the idea of flat black paint, such a powerful and understated look.
onebad2
01-20-2006, 02:41 PM
Looks great I remember when i was at that stage
trapin
01-20-2006, 05:45 PM
Brian...did you ever list the rotisserie in the for sale section? Did you sell it local?
i hope you had freshair when you were spraying that por 15 its not good to breath that stuff
Brian-Blade
01-21-2006, 04:09 AM
Trapin:
I still have rotisserie for sale , I have it listed at Camaros.net
for some reason I could not list it here for sale
PM or Email
[email protected] if you have any interest
RobM
Yeah that POR15 has some stong fumes
Used a good respirator & a some fans to get the fumes out
Johnny Blaze
01-21-2006, 08:50 AM
You have e mail!
Brian-Blade
05-11-2007, 10:30 AM
Been a LONG time since updates .finally got the car painted. I painted it myself at a friends paint booth. Pics dont do car justice it looks killer.paint is flat black PPG DP90 base with PPG Flex & Flat clear.
Looks good with shaved handles .shaved drip rail & all seams & tag holes filled
Car runs & drives ,need to finish a few mechincal things,addd all trim parts on & get glass installed (the only part of the car I am not doing ) Glass will be mounted with rubber moulding using no chrome trim.
I want to drive the car this sumer so I will work on all other details as I go or over the winter
Looks amazing.
My honest opinion here? The flat black is menacing. I'd stick with it for a while. Myself I'd do a set of black wheels with a polished lip on them, and possibly a black vinyl top.
Brian-Blade
05-11-2007, 09:19 PM
I agree , once it was done in this color & put the wheels on ...I dont think I will change it
Brian-Blade
06-22-2007, 05:24 AM
Got the car on the road .Been doing some debugging.
Holy christ the car handles amazing! I still need to get a front sway bar .
mdprovee
06-22-2007, 08:16 AM
Great progress, and I like the flat black.
whytry
06-22-2007, 09:01 AM
Hey Brian, good to see you on this site as well. I like your glass with the black trim it looks great!!
absintheisfun
06-22-2007, 06:05 PM
Brian,
Are those 80% quarters that you have put on?
formula98
06-23-2007, 01:38 AM
Hi Brian,
I just spent a few hours looking over your pictures. Your progress is great. How are you doing the glass? With the rubber seal are you moving the glass flush with the sheetmetal? do you have pictures of the glass install? I want to mount my windows the same and would love to see how you are doing it.
Thanks for sharing your project again great job.
Brian-Blade
06-23-2007, 03:17 AM
Brian,
Yes 80% quarters
Brian-Blade
06-23-2007, 03:19 AM
Hi Brian,
All pics I have on my signature pics
Here is the deal , the back glass & opening are stock untouched .The only thing done to the back glass was a black band was painted on (with glass primer) around edge, molding was then glued on. Rear glass was set in with tape & urethane glue.
The front has a some work into the opening.First the drip rail was removed which affected the pillar area.the top radius of the window opening were made more round & glass was ground with a bigger radius to let molding flow nice around radius. the pillars were extend to the top of fender.The cowl panel is mounted on in a different way due to the fact you dont need to use mounting clips .I welded 2 strips to lower cowl are & have 2 screws (covered in a plastic cap) holding rear of cowl panel down.The front glass also has a black band painted around it.Then the moulding was glued on.The front glass was also set in with glue & urethane
formula98
06-23-2007, 04:22 AM
Thanks for the info. Where did you get the molding that you used?
Brian-Blade
06-23-2007, 04:29 AM
The guy that did the glass had the molding in his van .The back moulding & the upper front molding are the same size .The front lower (on the cowl panel) is wider.
formula98
06-23-2007, 04:42 AM
Thanks Brian for all the great info. Keep up the great posts. I would like to see more of your project. Are you going to use the 67 wing vent? What are you using to open the doors?
Brian-Blade
06-23-2007, 05:10 AM
Yes I am using vent windows (that is the best feature on the 67 !) .I still need to paint the vent frame (flat silver color same as bumpers & grille).I am just using inside handle for now & once vents go in I can reach thru there. I dont see many times I am driving it that the windows wont be down or vent un-latched. I would like to run some electrical poppers but that is down the road . old school for now.
That car you are building looks real nice ,what is the eta for the car to hit the streets ?
formula98
06-23-2007, 05:45 AM
I'm thinking next summer. The LS2 is in Chicago and this summer we are moving from California to Michigan. So we have been in house selling mode and I have been busy figuring out how I'm going to get my project there and work on it at the same time. I have also put a lot of effort into the rear end and attempting to finalize a kit I can offer to others:secret: . Along with all of that I travel for work and get only (in most cases) the weekends to make it all come together. I have a great family and they all help.:woot: I'm sitting in a hotel in Germany right now replying to your post.
Your project looks great and has given me a few ideas and inspiration. Thanks for the posts and the info. I have always planned to remove the drip rails and wanted to do the black rubber trim around the front and rear windows, but not that far along yet. I saw your post and thought I would ask the questions. My brother and father own a body shop and my brother comes to visit every so often and we spend some quality time on my project. I still have to replace the quarters, tail section and DSE mini tubs before I can go much further.
My Brother and I are working out details of opening our own shop in Michigan for these types of projects. We are a year or two off, but have made it a goal.
Keep up the progress posts and I hope to meet up with you in Ohio some time next summer.
Car looks great. I've always liked the flat black idea. Do you know how the paint holds up in the elements (arizona sun)?
Brian-Blade
06-23-2007, 07:30 AM
It will hold up as good as any base coat clear-coat.It is a pre-flattened PPG clear .Part# DCU2060 - FLEXED N FLAT CLEAR
Brian-Blade
11-05-2007, 08:11 AM
Got started on next phase of work this weekend.
Pulled fenders & hood off , then pulled trans & engine.
Going to smooth firewall . I just bought a 383 @ 460 hp , still need to buy TKO-600. I picked up a 3.73 posi rear end over the summer & that is also going in.
Once all mechincal work is done I still need to finish interior.
I drove car all summer & fall & had a blast driving it.
With bad weather coming time to get to work
Specs of car:
Bmr upper & lower arms
QA1 coilovers
AGR Fast Ratio steering box
1 1/8 front sway bar
Soild body mounts
21st Centruy Street machine frame ties
Hotchkis Rear drop leafs With Bleistien shocks
245/45/17 front 255/45/17 rear Hankook Ventus HRII on Replica Alloy rims
4 wheel disc brakes with Summit adj. pro. valve
Body:
Shaved Door Handles
Shaved Drip Rail
All body seams welded & filled
Flush mounted Glass
Painted grille & bumper
Flat black Paint
Not top of the line stuff just the best I could afford
All work done be myself other than mounting glass
https://static1.pt-content.com/images/pt/2007/11/PB030107-1.jpg
https://static1.pt-content.com/images/pt/2007/11/PB040113-1.jpg
SatisTraction
11-05-2007, 09:44 AM
lets see some pics of the glass
Brian-Blade
11-05-2007, 09:56 AM
Here is glass
formula98
11-05-2007, 12:54 PM
It's nice to see your progress again. Keep the posts coming....
Brian-Blade
11-27-2007, 07:40 AM
Got the tranny shipped in yesterday & set the new motor & new trans set in last night.
It is just a test for checking firewall clearence to HEI . I am going to set back that area of the firewall a little bit make a radius notched filler panel ,as I thought I would have to as old motor was even closer.
That TKO 600 bolted up & the cross-member lined up dead nuts balls on !
I need to cut shifter hole a little bigger from the 4 speed shifter hole I put in (was an auto car).
Then pull the motor back & trans back out & start welding firewall panel on
https://static1.pt-content.com/images/pt/2007/11/PB060119-1.jpg
https://static1.pt-content.com/images/pt/2007/11/PB220179-1.jpg
https://static1.pt-content.com/images/pt/2007/11/PB260199-1.jpg
https://static1.pt-content.com/images/pt/2007/11/PB260201-1.jpg
https://static1.pt-content.com/images/pt/2007/11/PB260204-1.jpg
https://static1.pt-content.com/images/pt/2007/11/PB260206-1.jpg
formula98
11-27-2007, 07:52 AM
Looks like you have been busy! I'm waiting for my motor and would like to get moving on my project. Keep up the great posts....
Brian-Blade
11-27-2007, 08:20 AM
I have some good people helping with my project a drunk little dog !
https://static1.pt-content.com/images/pt/2007/11/PB220174-1.jpg
Brian-Blade
01-16-2008, 04:26 AM
Got the Firewall all done last night .
I am real happy the way it came out , alot of work but worth it.
Need to buy & install Flywheel & Clutch ,then the motor & trans go in & start bolt everything back on
https://static1.pt-content.com/images/pt/2008/01/P1150178-1.jpg
https://static1.pt-content.com/images/pt/2008/01/P1150180-1.jpg
formula98
01-16-2008, 05:20 AM
Looks great! Are you not going to run wipers? If you are where are you hiding the motor? Man I'm being inspired to get out in the "Man Cave" and get some work done!
Brian-Blade
01-16-2008, 05:29 AM
No wipers , Rain-X if needed still need to install side glass , I drove the heck out of the car all summer & only got caught in the rain once
Down the road most likley run a hidden motor
How's your car progressing ?
Brian-Blade
01-24-2008, 07:35 AM
Got the motor & trans set in last night
https://static1.pt-content.com/images/pt/2008/01/P1230189-1.jpg
formula98
01-24-2008, 08:46 AM
Hi Brian,
Sorry for not responding before now. My project has been on hold since last August. We moved from California to Michigan. I'm almost settled in and ready to start back to work. I'm guessing I'll get the new sheet metal in place around March - April time frame. I have most of the suspension work done.
woke up to -12 deg's this morning. It makes it hard to get out and work on anything.
Nice progress on your project. Keep the posts coming.
