Evoix
11-03-2012, 06:44 PM
bout time....
3.5L V6 EcoBoost Engine Kit M-6007-35T
https://static1.pt-content.com/images/noimg.gif SPECS
365 Horsepower @ 5,000 RPM
420 lb. ft. of torque @ 2,500 RPM
All-aluminum construction
10.0:1 compression ratio
Dual overhead camshafts with variable camshaft timing
High Pressure Direct Fuel Injection
Regular Unleaded Fuel recommended
Lightweight die-cast aluminum block with six-bolt press-fit main bearing caps with piston-cooling jets
Fully counterweighted forged steel crankshaft
High-strength forged powder metal connecting rods with floating pins
Lightweight aluminum high-strength pistons with low-friction skirt coating
Tuned composite upper and lower intake manifold
Dual water cooled Honeywell/Garrett GT15 turbochargers
6 quart die-cast aluminum deep sump oil pan
Engine weight is 417 lbs. (without accessory drive)
Engine Kit Includes:
Starter
Alternator
Front accessory drive and belt
Air cleaner assembly and ducting
Flexplate/flywheel
Can't wait to get out of Peru and back to the US to play with one of these....
Starter
Alternator
Flexplate/flywheel
