View Full Version : Changed plugs, cap, rotor & wires and not will not start.
kyost
11-02-2012, 04:25 PM
I changed plugs, cap, rotor, & the wires and now the engine will not start. I wired the cap with the correct firing order (4.3 Liter V6) 1.6.5.4.3.2,
I have spark from coil & also to plugs, I even sprayed starting fluid into the carb to see if that would do the trick. No luck
Any ideas would be greatly appreciated.
lineberrcasey
11-02-2012, 05:49 PM
can we get some background info? does it have fuel pressure?
Fuelie Nova
11-02-2012, 06:58 PM
Rotor tang not making contact with the coil terminal inside the dist cap.
Tom
kyost
11-03-2012, 06:45 AM
The van was running before I did the tune up it just hadn't had a tune up in years. I don't think there's a fuel pressure problem.
