First Bird
10-25-2012, 02:02 PM
Stupid is as stupid does. I did not use the gage holes when I installed my subframe. Instead, I ONLY measured diagonals from the Fischer Manual (and LCA zerk to leaf spring mount, etc) using a plumb bob, tram gauge and measuring tape. I had read that gage holes could be unreliable and that measuring diagonals was surefire. Now I can't get the hood opening square as I reassemble my 1968 Firebird (even with radiator support shifted all the way over). What went wrong is the driver side frame is ahead and the passenger side frame is behind the gage holes. I figure the frame is square but not parallel to the body work. Does that make sense?
I need to realign a subframe with welded subframe connectors. Here's my plan. What do you think?
1) Un-weld welded subframe connectors. Maybe borrow plasma cutter.
2) Leave front body work on. Loosen bolts at radiator support
3) Put jack stands under body rocker just below/behind firewall. Also put jack stands under rear axle.
4) Unbolt Exhaust From Headers
5) Remove Hood
6) Lift Engine just off the cradle
7) Loosen subframe bolts
8) Line up gage holes
9) Measure diagonals again, including diagonals of hood opening
10) Tighten subframe bolts.
11) Re-measure diagonals to make sure nothing shifted
12) Re-weld SFC's
Background info:
Before disassembly, a frame shop straightened the rear frame and measured the front subframe OK.
I used solid subframe bushings and welded in DSE SFC's.
I installed the Engine/Trans/Exhaust.
Fender to door gaps are good.
In searching internet and PT forum I find people have removed the subframe entirely without removing front body work. So I figure I don't have to remove front body work to just loosen and shift the subframe.
5) Remove Hood
12) Re-weld SFC's
Background info:
