View Full Version : One of my little in between projects, 83 stepside.
Twin_Turbo
10-19-2012, 12:32 PM
Not quite pro touring, yet. Will upgrade to some better front brakes, maybe susp. Thinking about building a long arm setup for the rear. In the mean time I have been redoing some stuff due to rust and decided to build a new & better engine for it with parts I had lying around mostly. No sense in sinking tons of money into it while I have other major money guzzling projects running (main proj. is 495LSX 82 Trans Am now) and some unfinished ones (road race 82 vette and 87 procharged iroc camaro)
So... the truck. Like I said not quite pro touring but it is lowered and has a lot of custom details on it, especially the interior, dropped it and it has rolled out fenders. It's got the blacked out look, what I like to refer to as road fighter look. My 82 TA and 88 Camaro beater have the same look.
I've been driving my truck hard for a couple of years and it hasn't done it a lot of good. For a while I used it for a daily driver because my DD was wrecked and I didn't want to drive any of my other cars (the ones that were not in pieces)
Last year I got a nasty rain water leak somewhere from the cowl area, right above the fuse box so I parked it, waiting for when I had time to figure out what was going on. I also blew 2nd gear out of the TH400, must be the clutches because when I put it in 2 manually it works (bands)
Here's what the truck looked like... shame I can't drive it right now. It was always a lot of fun.
https://static1.pt-content.com/images/pt/2011/10/24a0195a559704-1.jpg
https://static1.pt-content.com/images/pt/2010/08/24c46247e67fb4-1.jpg
This is probably the culprit...all that white crap. I have some minor bubbling of the paint on the bottom of the front fenders. Caused by a blocked drain hole and fender rolling... :(
https://static1.pt-content.com/images/pt/2012/10/24b4708d6959e3-1.jpg
Anyway...time to check out what's up. After pulling all of the interior out I could see daylight around the fuse box. Not good! Time to pull the brake booster, and sure enough..there was the ugly. 2 panels seperated and rust coming from in between. Probably cracked sealant from the brake booster and the wiper motor deflecting the firewall.
I cut out the offending piece and found what I expected to find.. rust holes
Time to cut out all the nasty and weld in a fresh patch. The section I cut out was beyond repair so I fabbed a new panel for that too.
I ground the welds a little smooth (this can't be seen anyway) and liberally applied corrosion protection and seam sealer.
Welded on the fabbed new front patch panel
halfway there
almost there
done
Now, everything else looks like a big mess. So, only thing to do is tear it all apart.
I took the front section out, repaired a bunch of nasty bubba welding repairs and misc. brackets baked on by an idiot with a stick welder.
https://static1.pt-content.com/images/pt/2012/10/24fa59f40111a0-1.jpg
https://static1.pt-content.com/images/pt/2012/10/24fa59f40b8f77-1.jpg
Old crap that came out (and some fresh powdercoated stuff in there)
I don't have a pic of the freshly coated rad frame, bracketry, lamp buckets and what not. (will this weekend)
So, what to do about the engine. It needed more oomph for sure and I have a lot of spare stuff from my camaros/trans ams and other projects. The decision was quickly made. I am installing a 3rd Gen F body serpentine system. This will take care of the annoying power steering belt whine. I only had 1 belt because I remove the other belt (no AC/smog pump) It's also a clean looking setup. I had it powdercoated matte black and the bolts are all gold zinc plated. The heads I also had lying around. Some TFS G1 Twisted Wedge heads. No one seems to like them, I do. I have 3 sets and only 1 set gave me guide wear issues because I was stupid enough not to use crane gold rockers and go with the recommended .010 longer push rod. A checker tool is a must with these to set them up properly.
I also have a complete HotRodLane/Street & Performance Multiport MPFI system lying around, it has a complete standalone harness w/ fuse box and a weatherpack ECM. Then I found my spare Procharger P600 bracket...and a P600 head unit :D Not a hard choice to make (can tune ECU myself, have the stuff..been there done that on 3rd gen camaro and GTA)
Initially I thought about running a Vortech carb enclosure..but EFI it will now be. I can run a 700R4 on it too without resorting to lockup kit (never worked to my liking on other cars)
https://static1.pt-content.com/images/pt/2012/10/250292947a3c62-1.jpg
https://static1.pt-content.com/images/pt/2012/10/2502929489deba-1.jpg
... nah
https://static1.pt-content.com/images/pt/2012/10/25029294b67a71-1.jpg
...yay!
https://static1.pt-content.com/images/pt/2012/10/25029294a7d26f-1.jpg
https://static1.pt-content.com/images/pt/2012/10/25029294a050bb-1.jpg
Twin_Turbo
10-19-2012, 12:33 PM
I have a Procharger FMIC for it but also have 2 smaller ones from a later F body. Have not decided which to run yet. I did remove the blanking plate from the rad shroud just in case. They are excellent holes to run piping through.
Repaired and powdercoated rad frame, assembled w/ all PCed parts (what a crappy pic, didn't notice that before...I suck at photography)
https://static1.pt-content.com/images/pt/2012/10/250327cf68f56e-1.jpg
Repaired and coated inner fenders.. a little dusty from sitting
https://static1.pt-content.com/images/pt/2012/10/250327cf7dcf1e-1.jpg[/QUOTE]
better pic of rad frame
https://static1.pt-content.com/images/pt/2012/10/2503aa29101ef0-1.jpg
pulled the engine/trans
https://static1.pt-content.com/images/pt/2012/10/2503aa29631601-1.jpg
what a mess
https://static1.pt-content.com/images/pt/2012/10/2503aa29786d77-1.jpg
https://static1.pt-content.com/images/pt/2012/10/2503aa298dbcfe-1.jpg
There was more rust in the firewall and fenders I have the firewall fixed now. I'll tackle the fenders later. Building a new engine for the car, still have to install the procharger.
I will coat the underside of the car with some type of rock guard so I didn't paint the firewall below the belt line
https://static1.pt-content.com/images/pt/2012/10/2505847801a1d2-1.jpg
https://static1.pt-content.com/images/pt/2012/10/250584781b07a9-1.jpg
https://static1.pt-content.com/images/pt/2012/10/25058478266f8b-1.jpg
https://static1.pt-content.com/images/pt/2012/10/250584783bc276-1.jpg
https://static1.pt-content.com/images/pt/2012/10/25058478473a1a-1.jpg
https://static1.pt-content.com/images/pt/2012/10/2505847852b5e9-1.jpg
https://static1.pt-content.com/images/pt/2012/10/250584785daaa7-1.jpg
Sprayed the chassis w/ stone chip stuff, nothing fancy
did some more work on the engine. Waiting for plated bolts and powdercoated parts to come in and my Summit order (new cam and bunch of other stuff) so i can put it back in. Did finish the wiring harness for the engine & EFI
Buttoned up most of the engine after receiving my summit order and getting stuff back from the powdercoater.
https://static1.pt-content.com/images/pt/2012/10/250688d3c01663-1.jpg
pan with oil return for SC and a heat exchanger so oil heats up more quickly
https://static1.pt-content.com/images/pt/2012/10/250688d3cb0315-1.jpg
https://static1.pt-content.com/images/pt/2012/10/250688d3d60978-1.jpg
https://static1.pt-content.com/images/pt/2012/10/2505f67e812925-1.jpg
Twin_Turbo
Forgot to pick up the bucket of bolts from the plater so I didn't have bolts for a lot of stuff. I did reinstall the powdercoated (custom) heater box and used torx screws to secure it all, much cleaner than what was in there.
https://static1.pt-content.com/images/pt/2012/10/25071cceb389de-1.jpg
https://static1.pt-content.com/images/pt/2012/10/25071ccea896e6-1.jpg
Wiring still needs to be cleaned up, I cleaned up the wiring for the front, still have to do the engine loom and the starter harness. I can not stand those crimper AMP connectors and splices. I solder and heat shrink all my connections.
https://static1.pt-content.com/images/pt/2012/10/25071cce9d36c4-1.jpg
Got the engine done, all it needs now is the supercharger and the intercooler & piping. Didn't have the bolts to put the IC and pulley on. All hoses and everything is new.
https://static1.pt-content.com/images/pt/2012/10/25071cce879942-1.jpg
https://static1.pt-content.com/images/pt/2012/10/25071cce92e9e6-1.jpg
https://static1.pt-content.com/images/pt/2012/10/25071cce7bd3a6-1.jpg
Progress is real slow, especially since it takes a lot of time to fix the hacked up wiring harnesses. I want to make them as clean as possible, redo all the connections and spliced with solder and heat shrink. I got all the harnesses done, except for the last section on the firewall running down to the starter and the section for the alt. charging wire and brake warning switch. All the others are done, the fuxebox is completely redone (some wires cut off with only a hair sticking out)
https://static1.pt-content.com/images/pt/2012/10/2507b283e5f4a1-1.jpg
https://static1.pt-content.com/images/pt/2012/10/2507b283fd2ffa-1.jpg
all the wires on the engine will have to be tucked away neatly too. I will mount the weatherpack ECM on the heater box. I disassembled the ECU so I can powdercoat the housing. Had to take it apart anyway to remove the calpak that was in there, I'll need to hook up an ostrich and do some tuning on it for sure and then burn a new prom and install that (so it's weather sealed again, which it isnt with the ribbon cable for the ostrich sticking out)
Bead blasted the steering shaft and had it zinc plated. The steering column end didn't come out so pretty because some residual grease leaked out and screwed up the finish so I painted that black
https://static1.pt-content.com/images/pt/2012/10/2507b283f2cfcd-1.jpg
The engine is fully assembled :D YAY thinking about either painting the SC black or installing a polished one that my buddy has, the polished look would go with the intake although I don't really like bling stuff. I'm all about matte black and machined & anodized aluminum
https://static1.pt-content.com/images/pt/2012/10/2507b28408361b-1.jpg
https://static1.pt-content.com/images/pt/2012/10/2507b2841305ce-1.jpg
https://static1.pt-content.com/images/pt/2012/10/2507b2841d469f-1.jpg
https://static1.pt-content.com/images/pt/2012/10/2507b284281654-1.jpg
https://static1.pt-content.com/images/pt/2012/10/2507b284336ec0-1.jpg
cleaned up rebuilt 700R4. Still needs deep sump pan (have it)
https://static1.pt-content.com/images/pt/2012/10/25081993c7df8c-1.jpg
dropped it all in
https://static1.pt-content.com/images/pt/2012/10/25081993d4072d-1.jpg
https://static1.pt-content.com/images/pt/2012/10/25081993decc9b-1.jpg
https://static1.pt-content.com/images/pt/2012/10/25081993e9f267-1.jpg
https://static1.pt-content.com/images/pt/2012/10/25081993f50456-1.jpg
https://static1.pt-content.com/images/pt/2012/10/25081994001a9d-1.jpg
https://static1.pt-content.com/images/pt/2012/10/250819940a866f-1.jpg
FRENCHBLUE72
10-19-2012, 02:34 PM
Nice....Diggin the s.c.
Trans
10-19-2012, 07:23 PM
Great tires on that POS!
craigs73
10-19-2012, 08:56 PM
really????
Twin_Turbo
11-24-2012, 11:08 AM
Not much interest apart from some low life POS who's apparent sole purpose here is to crap on other people's stuff. Probably just a zit faced foreskin waxer!
anyway
Not a whole lot of progress here, waiting on fenders to come in from the US. I did finish the exhaust system and all wiring. I also painted the supercharger black.
Next is doing the intercooler & ducting
https://static1.pt-content.com/images/pt/2012/11/250a41dd97c54d-1.jpg
https://static1.pt-content.com/images/pt/2012/11/250a41ddeeed80-1.jpg
All the IC piping is done
fabricated brackets for the IC, the thing had to be mounted at an angle otherwise the grille won't fit. It's still a tight fit nonetheless.
https://static1.pt-content.com/images/pt/2012/11/250b117826c83b-1.jpg
https://static1.pt-content.com/images/pt/2012/11/250b117847a2f4-1.jpg
Made it around the corners LOL
https://static1.pt-content.com/images/pt/2012/11/250b1178320d13-1.jpg
https://static1.pt-content.com/images/pt/2012/11/250b11781b19e7-1.jpg
And the other side... I cheated y making this a 2 pc section it would have been a major PITA to install it if it was 1 piece and the long silicone section gives me a lot more tolerance with engien movement.
https://static1.pt-content.com/images/pt/2012/11/250b1178537849-1.jpg
custom blow off valve
https://static1.pt-content.com/images/pt/2012/11/250b11785e0a90-1.jpg
done.. the tubing will be all powdercoated flat black.
https://static1.pt-content.com/images/pt/2012/11/250b1178692861-1.jpg
https://static1.pt-content.com/images/pt/2012/11/250b1178747123-1.jpg
https://static1.pt-content.com/images/pt/2012/11/250b11783c8889-1.jpg
Divine
11-24-2012, 11:46 AM
I love trucks like this. It's awesome without the overkill price tag. Definitely a hotrod. Nice work.
Twin_Turbo
11-24-2012, 11:59 AM
I could go balls out on it and get or build a new front and rear suspension for it but that would mean my 495LSX 82TA build would be backlogged even more than it is and I still have my full custom susp/steering/frame 82 twin turbo race corvette that I need to finish.
I don't want to put large wheels on it, I feel it doesn't look right. At the most I may do some 16" super wide rears one day, maybe use the spare 16" Hoosier Pro Streets I have but I don't want to cut up the bed. The rear is super nice and all flame inc coated before it was sprayed. Would be a sham to cut it up. As is I thik I can ruck a 315 in the rear, it's got rolled and bowed out fenders there already. (There's a 2" spacer behind those 10" wide rims)
Martin71RS
11-24-2012, 01:50 PM
Again a great build....I need to drop by sometime to see your projects in real life. I like the way you approach your projects...whish I had so many nice "spare" parts to pick from :-)
srh3trinity
11-24-2012, 02:31 PM
killer stance!
craigs73
11-24-2012, 09:58 PM
Looking good....... glad to see you painted the procharger....thought it stuck out with everything being black....looks just right now....cant wait to see it on the road
Twin_Turbo
12-01-2012, 01:06 PM
Got the piping all done, powdercoated flat black... dropped my camera and it's now kaput so crappy cell phone pics :(
https://static1.pt-content.com/images/pt/2012/12/250ba6523a7383-1.jpg
https://static1.pt-content.com/images/pt/2012/12/250ba6523f0b35-1.jpg
https://static1.pt-content.com/images/pt/2012/12/250ba652515332-1.jpg
https://static1.pt-content.com/images/pt/2012/12/250ba65259f8b1-1.jpg
https://static1.pt-content.com/images/pt/2012/12/250ba6526327ef-1.jpg
https://static1.pt-content.com/images/pt/2012/12/250ba652678ceb-1.jpg
Yelcamino
12-01-2012, 02:01 PM
Nice little "in between" project!
95riosnake
12-01-2012, 09:48 PM
Love this truck, I personally like the wheel/tire setup as-is, it gives the truck a kind of street fighter/old school feel. Upon re-reading your first post, "road fighter" is a great way to put it!
It would probably be a bit of work, but if you shaved the chrome drip rails and the trim band that goes around the back of the cab, it would give it a super clean look. Of course, that would require a bit of paint work too.
Twin_Turbo
12-24-2012, 03:23 PM
Decided to put my spark control here....it's a bit more of a wiring cluster F than I would have liked but oh well.... form follows function I guess
https://static1.pt-content.com/images/pt/2012/12/250d2fcd8647bd-1.jpg
Decided to redo the exhaust. It was already stainless but an ugly quickie job that I never really liked. Also the pipes are a bit small in the middle so I stepped up from 2.5 to 2.75 and tucked them up higher. I only finished the drivers side, the other side is still the old stuff. I had to modify the dr. side to clear my VSS signal adapter/cable coming out of the tranny.
I had issues with it scraping behind the collector. The exhaust now runs directly up from there with nice smooth bends.
https://static1.pt-content.com/images/pt/2012/12/250d78a7f1b481-1.jpg
https://static1.pt-content.com/images/pt/2012/12/250d78a7ecd814-1.jpg
other side done also
https://static1.pt-content.com/images/pt/2012/12/250d88bcd92838-1.jpg
https://static1.pt-content.com/images/pt/2012/12/250d88bce670ac-1.jpg
https://static1.pt-content.com/images/pt/2012/12/250d88bcea8f49-1.jpg
https://static1.pt-content.com/images/pt/2012/12/250d88bce261b1-1.jpg
https://static1.pt-content.com/images/pt/2012/12/250d88bcdda492-1.jpg
diesel25lrs
12-24-2012, 05:39 PM
Looking good! I like where your headed with this! See a few of these still on the roads but not like this!
mooseknuckles
12-27-2012, 12:42 PM
lookin good man!
Twin_Turbo
06-19-2013, 03:05 PM
better pics of exhaust
https://static1.pt-content.com/images/pt/2013/06/250f1a6f983ac0-1.jpg
https://static1.pt-content.com/images/pt/2013/06/250f1a6f93dd2a-1.jpg
https://static1.pt-content.com/images/pt/2013/06/250f1a9edefe01-1.jpg
https://static1.pt-content.com/images/pt/2013/06/250f1ab7e03d77-1.jpg
when the mufflers rust out I will replace them with some stainless ones, those are the only part that is not stainless ...well apart from the hideous hanger bracket the guy who did the exhaust for me years ago made... another reason to do everything yourself and not farm it out... people take short cuts
Got both tanks out, one had a pinhole the other has some rut also but it's not leaking. I repaired the pinholed one. The other is still airing out gas fumes
https://static1.pt-content.com/images/pt/2013/06/250f1a6fa1b9fa-1.jpg
When I get it back it will all be nicely powdercoated.
Finally picked up the contents of my container shipment. Apart from a bunch of parts for my various other cars (projects) the stuff for the truck was in there, some rust free fenders off an ambulance, a bumper with driving lights that I'll shave and put fog lights in and the remainder of parts needed to finish some stuff here and there (and the missing tank for the dually)
Powdercoater already had part of the parts batch done but not the tanks themselves so hopefully those will be done this week, same for the last batch of bolts and nuts from the plater...then it's time to rock & roll and get this thing together. With the fenders mocked up and the inners in place I will be able to finish the fuel system and finish my swirl pot for the EFI pump
For the rest there's a bunch of small stuff and trim pieces that came off the same parts car the fenders came off... and a whole bunch of parts for another one of my projects including a 495LSX short block.
Also got a slightly larger radiator for it. It's a used cup radiator. Probably needs mods to make it fit though
thank you amberlamps for donating these fenders :D
https://static1.pt-content.com/images/pt/2013/06/25122a71d0ad2f-1.jpg
https://static1.pt-content.com/images/pt/2013/06/25122a71d4e724-1.jpg
https://static1.pt-content.com/images/pt/2013/06/25122a71cab7c8-1.jpg
as it sits now
https://static1.pt-content.com/images/pt/2013/06/25120269f89280-1.jpg
That puny little radiator needed to go so I took 1 of my spare racing radiators (have similar ones in my 82 vette and 82 trans am), it's a dual pass. Only drawback is it's for a Y plumbed setup normally so it has 2 -12 inlets. I will fab a custom thermostat housing for it. Not a real big problem. This should keep things nice and cool and will plumb the oil bypass directly to the -12 oil to water heat exchanger ports, possible w/ a remote filter (have all those parts in spares for other cars)
This system also uses a remote pressure release valve (have it, also a C&R piece) and a reservoir. Will only be able to mount that after mounting the fenders, inner fenders, fuel surge tank and main fuel pump
https://static1.pt-content.com/images/pt/2013/06/2513bc8b1ba0ed-1.jpg
https://static1.pt-content.com/images/pt/2013/06/2513bc8b216f8c-1.jpg
Long time nothing new but I finally got my tanks back and got it all assembled again.
I had them back earlier and when I was cleaning them I found out they were coated poorly, the primer coat was showing through in some spots making for a cloudy whitish hue.
https://static1.pt-content.com/images/pt/2013/06/251bce29100708-1.jpg
Back they went and they came back looking good...only problem..I forgot the locking rings OOPS. They were in a bucket with zinc plated parts that I didn't take with me...crap.
https://static1.pt-content.com/images/pt/2013/06/251bce2927079f-1.jpg
https://static1.pt-content.com/images/pt/2013/06/251bce292c5ace-1.jpg
Also had to tacke the cooling system since the nifty rad I have in it has a dual -12 hookup instead of a big 20 or 24 (or a normal hose bung) so I had to fabricate something and decided to cut up and modify one of those cheap swivel neck thermostat things. Next time I'm buying a C&R billet one because this chinese POS is cast from something like bird doodoo.. I could not get a clean weld on it. The only cleanly welded part is the 2 an bungs welded together.. they are a clean aluminum alloy. The other stuff more resembles potmetal (welded that a couple of times when fixing headlight frames on C3 corvettes) what a royal pain. What left to do? Grind till it's semi clean. Hope it's not porous/leaking.
https://static1.pt-content.com/images/pt/2013/06/251bce29160e1f-1.jpg
https://static1.pt-content.com/images/pt/2013/06/251bce291b49aa-1.jpg
it even fits under the intake ducting :D
https://static1.pt-content.com/images/pt/2013/06/251bce2921a8b7-1.jpg
https://static1.pt-content.com/images/pt/2013/06/251bce29427f55-1.jpg
Next problem is my fuel system. Decided to put a mech pump back on the block, retain the low pressure switching valve system and have the pump fill a surge tank that will feed my aeromotive/paxton EFI pump.
This is the surge tank w/ hookups. Top most is the vent to the tank so it burps air out. The 2 others are feed from mech pump and return from EFI pump. The EFI feed is on the bottom. The large one on the top sticking out sideways will be plugged.
https://static1.pt-content.com/images/pt/2013/06/251bce29324106-1.jpg
https://static1.pt-content.com/images/pt/2013/06/251bce2937849a-1.jpg
getting fuller and fuller in there
https://static1.pt-content.com/images/pt/2013/06/251bce293c89b8-1.jpg
Tanks are in. Boy what a wrestling match getting these in without scratching them uo. These things are made to go on with the cab off. Not a fun job at all. Also when I had 1 in I realized the rear brackets were not the same and sure enough I had them mixed up :(
complete tank with sender retainer ring this time :)
https://static1.pt-content.com/images/pt/2013/06/251c0dd1739c0c-1.jpg
installed... glad I had them done in black and not gunmetal or argent silver like I normally do. These show and that would have messed up the blacked out look
https://static1.pt-content.com/images/pt/2013/06/251c0dd179225d-1.jpg
inner fenders back on. Soon I will fire this thing up for the 1st time
https://static1.pt-content.com/images/pt/2013/06/251c0dd17e4a82-1.jpg
CruizinKev
06-20-2013, 02:30 AM
good work so far man! :twothumbs
srh3trinity
06-20-2013, 05:23 AM
Do you own anything without forced induction?
68firebird
06-20-2013, 05:30 AM
me likes this too! looks great
85coupe50
06-20-2013, 06:03 AM
DAMN... That is a nice truck!
Twin_Turbo
06-20-2013, 01:15 PM
yeah, this truck and the camaro are the only cars I have with a supercharger. The others are not mine (lt1 vette, 92 1le camaro and 92 GTA)
I'm going to finish making it a driving car again and then i will piece together or fabricate something suspension wide. I want to ditch the rear leads and upgrade the front arms and brakes. Especially the brakes. I may end up installing seat belts again because it gets scary floating around on the front seats
COPO-RAT
06-22-2013, 02:16 PM
Kick A$$ truck! Love all of it.
Would love to know more details about fuel system and that intake. You can PM if you don't want to clutter up the thread.
Thanks!
Twin_Turbo
06-23-2013, 04:27 PM
The intake is a Speed & Performance piece. I think it's called a muptiport. Fuel system is a high vol. block mounted pump sucking out of either tank depending on which one is switched. The pump fills the surge tank that feeds an aeromotive (paxton label) pump off the -8 port on the bottom. The paxton supplies the high pressure fuel to the EFI and the return is to the surge tank. The surge tank itself vents from the top back to the switched tank. I initially was going to do in tank pumps but the switching valve is rated for low pressure and I couldn't get a high pressure one.
COPO-RAT
06-23-2013, 06:44 PM
Excuse my ignorance, but how in the world does a mechanical pump keep up with efi, and forced induction (rising rate fuel pressure...assuming 1psi per 1psi of boost)....I understand the mech pump is just filling the surge tank, but how does the efi (aeromotive/paxton) pump not empty the surge tank before the mech pump can fill it back up?
What is the capacity of the surge tank? I guess the return line back into the surge tank plus the mech pump filling the surge tank keeps up with the high pressure demand for the efi and forced induction? Is it really that simple?
COPO-RAT
06-30-2013, 09:00 AM
Hopefully my last post didn't come across as sarcastic or smart-a$$....was not my intent. I'm generally excited to hear how exactly this set-up will work, I'm not doubting it in any way! It would be something I would be greatly interested in duplicating for myself, I just want to make sure I understand completely.
It seems that the fuel would get heated up considerably. Just questions, not doubting!
Twin_Turbo
06-30-2013, 03:29 PM
there is no way the engine will consume enough fuel to drain the complete surge tank. It's constantly being filled by the mechanical pump and the EFI return goes to it as well. The mechanical pump just has to keep up with engine consumtption and all this without overcoming pressure. If it turns out the mech pump can't keep up the volume of the surge tank is a buffer. It will ahve to run almost dry before there;s an EFI pump feed issue. IF the mech pump can't keep up I will install one of my CV products pumps. The mech pump pumps 110 gallons per hour or thereabout, that's good to around 550-600HP. That's more than enough\
How would the fuel get heated up? There's a constant stream of fresh cold fuel and the warmer fuel and vapors ride to the top and excess is returned to the tank.
Twin_Turbo
06-30-2013, 03:32 PM
read this
http://www.sdsefi.com/techsurge.htm
Twin_Turbo
07-08-2013, 01:15 PM
This is the complete system minus the return/burp line to the top of the surge tank
https://static1.pt-content.com/images/pt/2013/07/251d9b6e09a77e-1.jpg
COPO-RAT
07-11-2013, 12:42 PM
Twin,
Thanks a TON for the info and pics!
Twin_Turbo
08-05-2013, 06:29 AM
Itīs running :)
http://www.youtube.com/watch?v=S6UBS5Vpp6E
have a small oil leak from the oil line supplying the SC. It's a nylon hose and for some reason it must have sprung a leak inside the braid..easy enough fix though.
Twin_Turbo
08-21-2013, 12:26 AM
Well, it all went too smooth. Crap was bound to happen. Sure enough I had no fuel going to my surge tank. After checking the hoses, the pump and everything I decided to do a test on the tank lines and sure enough blocked and partial blocked. The reason is I took the tanks off but there is no room to work there so I left the hoses a little longer to be able to connect the hard lines with the tanks dropped down a little. This kinked the hoses when the tanks were back in place because the hard lines are pretty close together. With no room to work I had no choice but to lift the bed and redo them with the little cramped space under the cab available. Took some cussing and swearing but got it done. Also painted the rear lamp frames black because the aluminum was oxidizing and I hate polishing stuff.
https://static1.pt-content.com/images/pt/2013/08/252128e368c142-1.jpg
hier moet je dus lekker zitten pielen en dat aan beide kanten
https://static1.pt-content.com/images/pt/2013/08/252128f1a7cd5e-1.jpg
^%$#^%^#%$^#$%^caramba!!
https://static1.pt-content.com/images/pt/2013/08/25213d1b2cc4c3-1.jpg
blacked out
https://static1.pt-content.com/images/pt/2013/08/25213d1b23a4d0-1.jpg
Now the pressure remains nice and constant and the surge tank is always full
1983 Chevrolet C10 Stepside Supercharged - YouTube (http://www.youtube.com/watch?v=OOO74eIg8qk)
Mr_Roboto
08-21-2013, 12:32 AM
dumb question what's the intake manifold? It doesn't look like a HSR. Just curious, it looks like it's optimized for a vette or F-body hood.
Twin_Turbo
08-21-2013, 12:59 AM
Street & Performance Multiport. Hotrodlane.cc It will not fit under a vette or f body hood (I tried)
It's damn neaeer identical to a HSR but a little less awful boxy looking. The base is a weiand/holley tunnel ram..just like the HSR
Here's some compare pics of the 2.
https://static1.pt-content.com/images/pt/2013/08/24d3d4a4003cc0-1.jpg
https://static1.pt-content.com/images/pt/2013/08/24d3d4a419d9b7-1.jpg
https://static1.pt-content.com/images/pt/2013/08/24d3d4a4340d7e-1.jpg
https://static1.pt-content.com/images/pt/2013/08/24d3d4a4556d32-1.jpg
Twin_Turbo
08-29-2013, 04:09 PM
Done :)
a little test drive...not much traction from these junk tires (peg leg)
http://www.youtube.com/watch?feature=player_embedded&v=OLp5zuI2x8k
https://static1.pt-content.com/images/pt/2013/08/2521b7a187931b-1.jpg
https://static1.pt-content.com/images/pt/2013/08/2521b7a17b7f3a-1.jpg
https://static1.pt-content.com/images/pt/2013/08/2521b7a18220aa-1.jpg
https://static1.pt-content.com/images/pt/2013/08/2521b7a18d190e-1.jpg
https://static1.pt-content.com/images/pt/2013/08/2521b7a1931e4a-1.jpg
Z06killinSBF
08-30-2013, 06:36 AM
Very cool build, is the truck green? Looks killer!
Twin_Turbo
08-30-2013, 08:17 AM
It's very dark blue metallic. The only thing it's lacking now is a set of bigger rims and brakes. I think I will throw on some spare BBS wheels I have to see how it looks. Ordered some 6x5 to 5x4.75 adapters for that. In the future (probably sooner than later) I'm going to see if I can fit a 3rd gen camaro 1LE hub (turned down rotor) on the front of the belltech drop spindles. I think they use the same A3/A6/8817 seal combo. If that does fit I'm cutting the ears off the spindles and will be installing some 14" rotors w/ some spare c6z06 calipers I have. That will give me a 4.75 bolt circle up front so I can do away with the adapter there.
vette427-sbc
08-30-2013, 10:35 AM
Sounds wicked! And I like the Audi badges too...
Twin_Turbo
09-01-2013, 12:43 PM
It's not an audi badge, it something off ebay. Figured it'd be kinda neat.
All done. I may end up swapping to 32lbs injectors because I need more fuel and may be maing out these injectors even out of the boost range. Got some 32s lying in the truck so I can swap them out sometime soon. For the rest it drives fine, and smooth. Love the OD, it does an easy 80mph @ 2500 or so rpm.
Put a moroso crank case evac system on it to keep the yucky filth out of the intake
https://static1.pt-content.com/images/pt/2013/09/252226d48790d8-1.jpg
new washer reservoir, custom expansion tank & acoompanying overflow for the rad
https://static1.pt-content.com/images/pt/2013/09/252226d476c933-1.jpg
WBO2, chose this style because the gauge most closely matches the stock ones. (ignore dust)
https://static1.pt-content.com/images/pt/2013/09/25223a49c11a9f-1.jpg
interior all back together
https://static1.pt-content.com/images/pt/2013/09/25223a49c65ed3-1.jpg
Done :)
https://static1.pt-content.com/images/pt/2013/09/25223a49cb8a98-1.jpg
https://static1.pt-content.com/images/pt/2013/09/25223a49baa046-1.jpg
Glad to be driving in it again... it really is one of the must fun cars to drive... it's rattle free, lots of room and now plenty of oomph.
95riosnake
09-07-2013, 06:46 PM
Any video footage? I love this truck :cheers:
Twin_Turbo
09-08-2013, 03:15 PM
It left me stranded LOL. Current theory is that there was some uneven spots on the powdercoated alt pulley and somehow even after tightening it with the impact it got loose. The lock washer machined the cneter out of the pulley in no time. I started hearing a squeeling sound and within a couple of miles it was over. Lost belt, no p.st. no wp and no alt. NICE :( Was on my way to a car show, I had been working long hours on it to get it done in time only for it to quit on my 5 miles before the meeting grounds
https://static1.pt-content.com/images/pt/2013/09/2522b9c64b049a-1.jpg
https://static1.pt-content.com/images/pt/2013/09/2522b9c650a469-1.jpg
some footage (I thought I had posted them here but here it is again)
http://www.youtube.com/watch?v=OLp5zuI2x8k
http://www.youtube.com/watch?v=58JuDqm9DTY
95riosnake
09-16-2013, 06:33 PM
Sounds tough in the videos! That sucks about the pulley, but on the bright side it's less embarrassing for it to happen on the way to the show rather than while idling on the way out of the show when everyone is watching, lol.
Dutch455
09-17-2013, 04:31 AM
NIce! Also nice to see a fellow Dutch Pro-Touring member ;-)
Greetings from Rotterdam
Dutch455 (aka K5blazer @ AAP)
