View Full Version : Suspension Upgrade questions for an 83 Monte Carlo
rmorman
10-17-2012, 08:21 AM
Howdy!
I currently own a '79 & '83 Monte Carlo. The '79 has had several engine and suspension modifications including a Hotchkis TVS Suspension System (http://www.hotchkis.net/7888_gm_gbody_tvs_system_small_block_w_extreme_swa y_bars.html) and a set of Edelbrock shocks. I REALLY like the way it handles. Recently I inherited the '83 MC. Although the outside has been completely restored, the suspension system is stock. That is quite apparent when you drive it. I'm not planning on going as far with the '83, but would definetly like to upgrade the suspension a tad.
Here is my question. Should I go with the G Body Sport Sway Bar Set (http://www.hotchkis.net/7888_gm_g_body_sport_sway_bar_set.html) or is it worth the money to go up to the GM G Body Extreme Sway Bar Set (http://www.hotchkis.net/7888_gm_g_body_extreme_sway_bar_set.html)? At the same time, I think I should replace the shocks. I was looking at the HPS 1000 Shock 4 Pack (http://www.hotchkis.net/hps-1000-shock-4-pack-7888-ag-body.html), but was not sure if that was overkill as the shocks are not inexpensive. The '83 has the stock 305 and I do enjoy driving into the curves but don't plan on doing track racing with it. Thoughts?? Or do I need to go a complete different direction?
Russ
rmorman
10-18-2012, 07:28 AM
I have been asking around and searching the internet. Does anybody have any expierence with the SC&C "The Basics" Suspension Package 1978-88 GM A/G Body (http://scandc.com/new/node/767)? It seems to be a cost effective way to get some handling performance from the Non SS Monte.
Russ
Randy67
10-18-2012, 08:09 AM
SC&C would be a great way to go, Mark has done alot with G-bodies so he knows what works. They are also used in roundy round racing so there are parts available that way, but you have to figure out what you need, no packages that way.
