View Full Version : My 65' Impala SS Project....
nicke
10-16-2012, 11:15 AM
Hey folks,
I have been here for a while, but am just now getting around to posting some pics of my car. I bought this car when I was 16 in 2000, as my first car. Have always loved this body, and although I have changed my mind a million times on the direction of the build, I seem to always have a bit of pro-touring inspiration. Really, I just like to drive it and am happy to change whatever is necessary to make that experience more pleasurable.
So, though I would love to have an LS engine, I currently have the correct 327, with a mild cam and camel hump heads. Hindsight is 20/20, so if I were to do it over, I would have built a big block or LS. Once this engine gives up, LS it is!
I swapped the powerglide for a 200-R4, and changed gears from 3.07 to 3.73 in my 12 bolt. This made a huge difference! I also, put 13" disc brakes up from and added a power booster.
I am running 18" wheels up front and 20" wheels out back, and again, didn't know what I know now when concerning my tire choice. I will choose differently once these wear out. I added dropped spindles, and 3" lowering springs in the rear, and have no rubbing issues at all and I do like the stance.
I also upgraded the standard 20:1 ratio steering box to a 12.7:1 quick ratio steering box, which give much more responsive steering and road feel.
Future mods will be upgrading my factory rear control arms and going with poly bushings. Also, will be adding an upgraded sway bar for the front, and putting a bar out back.
Not long after adding my brakes last year, I hit a deer and crunched in my front end and ended up getting a new clip. I decided to replace the rear quarter as it showed signs of a poorly done previous repair, so I am currently learning to weld while I put that panel on. After I finish the body work, I'll put on a fresh coat of white and drive!
While not through and through pro-touring, I chose mods that give me no excuse to not drive this car. It was my daily in high school, and in college, and I am now able to have it as my secondary car. Also, I love seeing all your high dollar cars, but enjoy the fact that I have done literally everything to this car myself. Like many of you, I will NEVER be getting rid of this car, and I am as excited to drive it today as I was when I first got it.
Pre- Deer Incident:
Deer Damage:
The rebuild/ current condition:
Quarter Panel Replace:
First time welding... go easy on me :eek:
And there you have it!
-Nick
Trans
10-16-2012, 11:17 AM
Are you gona go down to bare metal on the whole body and then just clear it?
nicke
10-16-2012, 11:24 AM
Nope, not going to go to bare metal.. just down as far as it needs. Then a fresh coat of white.
-Nick
ILLMATIC
10-16-2012, 02:37 PM
one of favorite IMPALA
lineberrcasey
10-16-2012, 06:47 PM
love the car man im thinking about painting my 70' the same color either white or black but that's years down the road lol
Rick Dorion
10-17-2012, 12:36 AM
Keep the info coming. Who's quarter did you use and how was the fit?
nicke
10-17-2012, 08:16 AM
Thanks guys.
I purchased the quarter locally, though it is the same quarter that all the repo houses carry. I am under the impression that they all come from the same place, then are labeled once they get here.
As far as fit, its wasn't too bad. The lines aren't as great as original, but actual fit wasn't too bad. I did make some of the usual adjustments by trimming parts of it. Hope that helps.
-Nick
Lamoogle
10-17-2012, 09:06 AM
Nice car man, I love Impala's and keep up the good work!
Glenn
10-17-2012, 02:53 PM
Very cool build Nick, love it.
Trans
10-17-2012, 04:07 PM
When are you gona throw more meat on those rims,maybe even go wider to fill in the fenders.
nicke
10-17-2012, 04:24 PM
I know right. In my first post, I admitted to poorly picking the tires. :guilty: I mentioned that once these wear out, I'll be choosing more wisely the second round. Also, might go with a 10" wide rim in the back, or re-do my wheel choice altogether... we'll see :)
-Nick
nicke
10-17-2012, 08:37 PM
After getting the body work and paint done, I will finish up the suspension. Besides adding sway bars and new rear upper and lower trailing arms with poly bushings, I was thinking of doing some type of tubular a arms for the front. I know a few companies make them for this car, though I don't know if they are needed/will make much of a difference. Also, I will be upgrading my shocks all the way around, and maybe going with some type of performance coil over. I haven't decided exactly what supplier to go with yet, but I am doing research. I haven't seen many examples of these 65-70 full size chevy's done like this, as they certainly aren't the choice for a PT starting point, but I would like to get handling to a more modern level.
Also, I am pretty fond of my current wheels, though I would like to look at something a bit more modern down the road, where I can get the fitment just right, filling up these large wheelwells. Any suggestions as to what might look good on this car?
-Nick
lineberrcasey
10-17-2012, 09:59 PM
rocket racing has some sick wheels anything with 5 spokes i think is best on impalas
nicke
10-18-2012, 08:08 PM
ummm....:lol:
nicke
10-21-2012, 09:30 PM
Any opinion on Hotchkis sway bars? I see a few other companies selling them for these big cars, and see both hollow and solid. What is the advantage to either?
-Nick
nicke
10-28-2012, 11:54 AM
Just got my new exhaust installed. I think she sounds good.
http://vimeo.com/51019821
-Nick
Glenn
10-28-2012, 01:22 PM
Sounds Gooooooooooooood :)
nicke
10-29-2012, 10:34 AM
Thanks. Its no LS, but does get down the road decent with the new set of gears.
-Nick
nicke
11-04-2012, 11:08 PM
Few shots of my interior and engine compartment...
-Nick
nicke
02-15-2013, 08:09 PM
Will be installing this bar this weekend. I will also be adding a rear bar soon, but contemplating going tubular rear control arms and poly bushings...
coolwelder62
02-16-2013, 01:29 PM
Wow!!,I dont know how I missed this thread.I love the 61 & 65 Impala's.Someday will have one of each.
nicke
03-27-2013, 08:04 AM
Thanks! Yea, its coming along nicely! Ready to finish that quarter panel up, paint it and drive!
nicke
06-02-2013, 05:09 PM
Just finished installing the new front sway bar. Rear is on its way. I can say that the new, thicker, front bar makes a ton of difference as compared to the stock front bar!
I'm looking forward to getting the rear bar on!
nicke
07-23-2013, 02:40 PM
Rear bar going in shortly. I also just finished up putting in the air ride in the rear.
nicke
07-30-2013, 08:32 AM
Got the rear air ride install completed. The front bags will be next.
http://vimeo.com/71307478
alocker
07-30-2013, 03:17 PM
What kind of sway bars did you buy?
dropped72ss
07-30-2013, 04:11 PM
Nice looking impala!
nicke
07-31-2013, 06:49 AM
Addco 1 1/8" front and Addco 1" rear.
nicke
07-31-2013, 06:50 AM
Thanks! Its coming along!
67apostle
09-14-2013, 08:47 PM
Nice ride... I just purchased a 65 SS and i can't sleep at night. lol... I can't wait to get her on the road.
Buryingthesun
09-15-2013, 05:00 AM
Looks nice
nicke
12-10-2013, 01:22 PM
Thanks guys. I think you guys are all rubbing off on me.
I just picked up an L92 and 4L80E that I will be swapping in soon. More to come on this.
nicke
12-12-2013, 03:24 PM
nicke
02-26-2014, 09:18 AM
Getting closer.
nicke
05-23-2014, 10:19 PM
She's Alive!
nicke
02-15-2015, 06:57 PM
The engine is in and I got all the bugs worked out. Even a new coat of paint on her!
https://vimeo.com/93771557
New Exhaust!
https://vimeo.com/100967696
-Nick
Stained Soul
02-15-2015, 07:35 PM
Looks great Nick,
damn nice job.
When you going to bring her over ?
L8R man,
Stu
Windycity1
02-16-2015, 08:58 AM
109093
Windycity1
02-16-2015, 09:02 AM
Hate I sold it.
nicke
02-16-2015, 05:34 PM
109095
Damn! Great looking 65!
-Nick
Djsmith1996
04-21-2015, 08:09 PM
My wife and I were gifted her deceased uncle's '65 impala (non SS). It's been parked in my wife's grandparents back yard for 20 yrs. I'm going to go a similar route with as your build. UMI rear suspension and global west tubular up front. The car had hydraulics back in the day so all the stock suspension is trash. I'm also going the LS route as the motor was shot anyway.
It's currently in the middle of body work as there was significant rust in the window channels due to a sunroof installed 20 yrs ago. I'm still learning about the '65 but what antennas are you using? I like that they are more subtle in length.
