View Full Version : C6 Z06 rear brakes... ford Nine Inch
XLexusTech
10-13-2012, 01:11 PM
I saw these cool brackets from GMR and got to thinking... what are most people using for mounting brackets and E brakes?
Jdinjax
10-13-2012, 04:18 PM
I'm running Kore3's C6 Z06 rear brakes on my Currie Nine inch (Torino). Can't beat the performance and looks for the money IMO. Excellent system...
Ron.in.SoCal
10-13-2012, 05:12 PM
Call Tobin. Done.
TheJDMan
10-13-2012, 06:34 PM
I initially called Kore3 to order weld on mounts but I got tired of waiting for a reply and fabricated my own. That said I plan to redo them this winter with the GMR mounts and add the GMR park brake calipers while the rear end is out.
Jay@GMR
10-13-2012, 06:45 PM
Depending on what rear brake kit you currently have...... our bracket MAY allow you to use what you have (hat/rotor/park brake) and simply remove your existing caliper, and replace by installing our bracket and your/our ZO6 caliper.
Jay@GMR
10-13-2012, 06:52 PM
Sounds good Steve :twothumbs Just give us a shout.
68sixspeed
10-13-2012, 08:16 PM
I have kore3's setup for the 9" rear, no issues with 2 years use on it, no welding req'd.
XLexusTech
10-14-2012, 04:59 AM
Yep Kore 3 is good stuff but I amready have calipers and rotors...
csouth
10-14-2012, 01:05 PM
You could just by the Ford caliper brackets from KORE 3 if you want. I was going to get some for the 9 inch I'm building. I already purchased brackets for my Olds rear from Tobin, so Tobin suggested I use GM axle ends instead of buying another set for Ford.
