View Full Version : who has installed their own DSE coil over kit?
SatisTraction
08-01-2005, 09:22 AM
how complicated was it and how many hours did it take? i am thinking that this may be my next "project" :)
camcojb
08-01-2005, 10:08 AM
I did mine and am helping a friend with his. Could easily be done in a day. Cut-off wheels and/or plasma cutter sure makes it faster, although a sawzall will also work. Spend most of the time removing the stock upper shock mount/cover and then grinding the subframe to make it look good.
With the jig DSE supplies the guesswork is taken out; just bolt it on, fit the pieces to it and weld it up. If you are not an experienced welder I would have someone else do the final weliding, this is going to be supporting the front of your car.
https://static1.pt-content.com/images/pt/2005/08/susp20002r-1.jpg
https://static1.pt-content.com/images/pt/2005/08/susp20001r-1.jpg
Jody
baz67
08-01-2005, 04:57 PM
I second what Jody says. It can be done in a day. Cutoff wheels and a sawzall did wonders. I have a 110 welder so I went to a welding shop for the upper control arm mount fo better penetration after I tac welded the mount into place. I use my 110 for the rest.
Lowend
08-01-2005, 05:04 PM
Ahem - you do have to have the engine out of the car to install
SatisTraction
08-01-2005, 06:10 PM
my camaro has not had an engine since 1981 :) i have only owned it for 6 months and have a ls1/t56 ready to drop in :)
JayBird
08-02-2005, 04:37 AM
Diddo on what Jody said. It took me a day to do mine. That included alot of grinding and welding on the subframe to make it look like I wanted. It can easily be done in a day.
You'll love how it handles!
