View Full Version : how do you tighten ridetech front coilovers
ohm
10-03-2012, 02:29 PM
I am installing ridetech front coilovers on my 69 camaro. I can't figure out how to tighten the top nut on the shaft without the shaft spinning. I don't want try to clamp the shaft and risk dinging the shaft in turn having a leaky shock. It's a stock sub frame with ridetech single adjustable coilover. Any ideas would be greatly appreciated.
xplane
10-03-2012, 02:45 PM
My coil overs had a flat at the top which i held with a wrench and snugged the nut with a seperate wrench.
Yelcamino
10-03-2012, 02:52 PM
If you haven't already, remove the black plastic rebound adjustment knob. Once the knob is out of the way, you'll see the top of the stud is a small hex which you can put a wrench on to hold the shaft while you tighten the nut.
ohm
10-03-2012, 04:01 PM
Yelcomino I saw that and was wondering if it was strong enough. I will give it a try. Thanks!!!
bret
10-03-2012, 06:46 PM
Do not over tighten...the swivel ball assembly must be able to have movement.
