View Full Version : 3.43 or 3.73
72'Monte
10-02-2012, 11:31 PM
OK GUYS,i'am building a mean street car.i plan to put a 500hp sbc stroker motor in it with a overdrive trans.but it has a stock 350 motor and trans in it.the car has 3.43 in it now.should i get 3.73's for it?
SkinsandJrfan
10-03-2012, 02:25 AM
I have a 68 Camaro with a 383 stroker, T5 trans and 7.73 gears. I'm pushing about 485 hp and I get 16mpg on the highway. It pulls very hard in first and 2nd gear as well. Not sure the difference in the 2 sets of gears but that's how I'm doing on a similar set up as you are talking about.
dontlifttoshift
10-03-2012, 04:27 AM
7.73? must do bad a$s wheelies.....
If I was starting from scratch I would go 3.73. If the 3.43 is already there run it for a while and see what you think, it won't cost you anything to not change it and you may find it works with your engine.
69cutlassrkt
10-04-2012, 07:42 AM
being a th350 I would keep the gears in it. If you want a faster take off or you want it in the powerband sooner change the torque converter to something that stalls a little higher. The gearing would probably be enough for the stroker build. What trans were you considering going to?
72'Monte
10-08-2012, 01:53 AM
i'am going with a 2004r 0r maybe a 7004r trans in it.later on down the road i like to put a 5 or 6 speed stick in it.
72elco
10-08-2012, 03:56 PM
If im not mistaken a 700r4 has a steeper first gear than a TH400 or th350...i am running a 383 700r4 342 rear and it launches pretty hard, if i keep my foot out of it (rare) i can get 16-17 mpg. Run it how it is and see if its what you want. I think 373 would be a bit much but 355s maybe a nice alternative. my2cents
BonzoHansen
10-08-2012, 04:49 PM
If you want a stick in it and don't have a trans now why bother with an OD auto trans? Seems like a waste of money. Not like a A-OD for 500hp is a cheap proposition. trans choice matter - 1st gear and top gear. Pick a trans and ask again.
72'Monte
10-11-2012, 08:58 PM
sorry,i'am getting a head of myself.
