TheMeat
09-29-2012, 11:05 AM
Hey guys, I am selling my entire set-up listed below. It has maybe 10K-15K miles on it?? Just a guess though. I have receipts for ALMOST (camshaft and timing chain I cannot find) everything listed below. This is a parts list of what is included with the engine. Basically you will need a carb, air cleaner, and fuel pump to go with this engine. I will include the brass tipped fuel pump push rod to the buyer for the roller cam. I have the dyno sheet to prove this engine made 360 RWHP and 405 RWTQ with everything listed below, small 1 5/8 headers, and a 3K stall nitrous converter bolted to a Turbo 400. Larger headers and a single plane intake should up the HP 20-30.
This engine is an absolute blast to drive with tons of low end torque, revs like a chain saw, and has a nice lopey idle. I have a third gen aluminum radiator, Ford Taurus electric fan, and 190 thermostat and it never runs hot. I still use my factory AC and power brakes. The oil is changed religiously with 20-50 Valvoline VR1. I will include a brand new set of FelPro header gaskets and a FelPro 1 piece oil pan gasket.
The engine is still in the car and will be until sold. I have zero issues in providing a test ride to potential buyers and will attempt to post a video shortly. The car will be in Tucson Arizona after October 7th.
Any questions PM me.
$3,000 $2900
-400 SBC 10:1 compression (91 octane compatible)
Balanced, have balance card
.030 Over 4-bolt main GM block
TRW Forged pistons( L2352F)
Plasma molly rings
ARP rod bolts on stock reconditioned rods
-Lunati Hydraulic Roller Camshaft (20120712)
Advertised Duration (Int/Exh): 282/290
Duration @ .050 (Int/Exh): 231/239
Gross Valve Lift (Int/Exh): .535/.550
LSA/ICL: 110/106
RPM Range: 2400-6200
-AFR 195 Eliminator Heads W/65cc Chambers angled plug (1040)
-ARP PRO SERIES rocker studs (234-7201)
-ARP head bolts( 134-3601)
-Comp Hydraulic Retro Fit Roller Lifters (853-16)
-Harland Sharp Roller Rockers 1.5 ratio
-Edelbrock RPM Air gap manifold (7501)
-Cloyes HEX-A-Just True Roller timing chain w/Torrington bearing
-BLP Products billet two piece timing cover (6000)
-ARP timing cover bolts (400-1502)
-Acell HEI
-larger capacity oil pan (I think Summit 7 quart)
-Milodon pickup tube (18314)
-PRO/STREET Harmonic Damper (24266)
- Pro Form Polished Aluminum water pump (67264)
https://static1.pt-content.com/images/pt/2012/09/engine-1.jpg
https://static1.pt-content.com/images/pt/2012/09/engine2-1.jpg
$3,000 $2900
Plasma molly rings
LSA/ICL: 110/106
-Acell HEI
