View Full Version : need help with T56 install
Moose
07-30-2005, 01:41 PM
I purchased a T56 for my 69. The tranny came from a 95 Trans am. It came with bellhousing, clutch and shifter.
How do I convert the clutch from the cable setup to the hydralic? and what else will I need.
Thanks for the help
mike
zbugger
07-30-2005, 02:11 PM
Talk to the guys at ATS. They can set you up with everything you need.
andrewb70
07-30-2005, 02:48 PM
What car do you have? I am not aware of any 69 GM vehicle that used a cable clutch.
Samckitt
07-30-2005, 06:18 PM
If it came from a 95 Trans Am it would have been Hydraulic from the factory. If someone switched it, then couldn't you just buy the GM parts?
Scot
Moose
07-31-2005, 01:13 AM
I have a 69 camaro.. The only thing left in my car is the pedal assembly. previous owner switched the car to a auto..
Moose
07-31-2005, 01:15 AM
Edited:throw:
Samckitt
07-31-2005, 06:07 AM
To switch to hydraulic setup on your car you will of course need the hydraulic setup for the tranny. Then you will need to fabricate some type of bracket that holds the hydraulic master cylinder. I made one to sandwich between the brake booster & the firewall. Then the master cylinder mounts to it. I then welded a portion from the factory T56 clutch pedal that the master cylinder apply rod mounts to.
Bracket looks like this: http://mysite.verizon.net/res722js/ug_brkt.jpg
And of course you will probably have to cut the floor for the shifter & fabricate the crossmember.
Also I think there is a company(s) that makes aftermarket hydraulic setups. So if the hose is not long enough you can have one made.
Scot
TitoJones
07-31-2005, 11:42 AM
We make a kit to allow the bolt in of that T56 to your car. Check our website out for details.
http://www.t56kit.com
Tyler
Moose
07-31-2005, 12:23 PM
Tyler I emailed you this morning about the prices for the kit.. can you send me a pm and how long it would take to get it to me..
defintly need it
samckitt thanks fro the great info..
Mike
Moose
08-03-2005, 02:43 AM
http://www.t56kit.com (http://www.t56kit.com/)
Tyler
tyler.. how can I order the kit..
I called and left ya a message..
Mike
TitoJones
08-03-2005, 03:48 PM
Sorry for the delay, you can order with us in Email or phone-
[email protected]
or
702-245-6305
Tyler
