JohnW
09-26-2012, 11:31 PM
So at this point I have 3x1.5x1/8" box tubing to build frame rails out of coming back from my front subframe. Like this:
https://static1.pt-content.com/images/pt/2012/09/turbopintoproject0022-1.jpg
It's going in my Pinto, and I'm planning a 3-link torque arm rear end later on. This is a rough sketch:
https://static1.pt-content.com/images/pt/2012/09/aTQPS-1.jpg
But at this point, all I can do is run the rails down the floor. I have until Sunday to get this done and won't have a chance to do much else for a while due to a move. I want the main part of the rails in now so the floors will be pretty much done and I won't have to worry about them. This won't interfere with anything else in the car and I'll be able to drive it until I'm ready for the next step. What I'm concerned about is how I'll be attaching the rear later. I want to weld a gusseted plate in as a bolting point before the rails go in, as I won't be able to get a welder in to add anything later without hacking up the floor. The plate will be lined up with the slope of the rear floor behind the back seat.
This is in a Ford Pinto that currently weighs 2400 pounds. I'm expecting it to weigh around 2600 once I'm done between a lighter motor and some structural reinforcement.
Now my questions are:
1. Is making a bracket to bolt the rear end on like in my drawing a mechanically sound idea? I think it should be if I take precautions to prevent the box tubing from crushing when bolted on and use the proper bolts. The control arms will be mounted to these front rails and the subframe I'm planning to make and bolt on later will be taking the forces from the coilovers and panhard bar or Watt's link.
2. If it is a decent idea, what size and thread pitch bolt should I use? I'm planning on using 4 bolts per side. I was thinking 5/8" would be good but I'm not sure, and I'm under the assumption that fine thread is better here right? I have to know what I'm going with before welding this all together. I'm planning on welding something along the lines of this (http://www.fastenal.com/web/products/detail.ex?sku=37892) in, instead of threading the plate because there wouldn't be much thread contact.
3. If this is a bad idea, what would be a better way to do it?
