View Full Version : Is this 9" Center a posi?
csouth
09-25-2012, 01:07 PM
The seller says this is a posi and before I ride to look at it, I was wondering how to identify it outside of the housing with no axles? I found somewhere where it said the recessed ring bolts would indicate it being posi. I'm not too familiar with Ford rears, but may be able to build one for a decent price. any feedback would be appreciated.
https://static1.pt-content.com/images/pt/2012/09/9pig-1.jpg
Josh
09-26-2012, 04:49 AM
Yes, the basic way to ID is by the recessed ring gear bolts on a stock Trac-lock. Be sure there is no hairline cracking in the metal flange betweeing the ring gear bolts.
BBPanel
09-26-2012, 05:26 AM
Its a little hard to see in the pic - are those "recessed"? How much ~1/8" or so?
csouth
09-26-2012, 12:39 PM
It is posi, but after talking to a friend that is a Ford guy I'm not touching it. It is a 9 3/8 or called 9.5 Seems it will fit a regular 9" housing with a little modification, but a lot of the parts do not transfer between the two carriers. On to the next.....
Josh
10-01-2012, 04:53 AM
Run Forest, run..
