View Full Version : BigStuff3 ECU and harness - new
MrForce
09-19-2012, 12:02 PM
BigStuff3 ECU and harness. Part# 004-002 for engines with distributors. Will not work on LSx engines This is the racers favorite with internal data logging and wideband O2. It is new in the box and I will supply the MAP sensor of choice (1, 2, or 3 bar) for your application. Retail is $2100
$1650 shipped
Rob
64685
aronhk_md
09-19-2012, 07:42 PM
Damn, I want...lol. Perfect for my turbo'd 455. But all my play money is tied up at the moment. GLWS
Takid455
09-20-2012, 07:28 AM
What is required to run it DIS? ie use w/ dizzy now and still be able to use w/ DIS at later date?
MrForce
09-20-2012, 10:13 AM
As is, it can only be used with a dizzy. An add on box can be used to drive 8 coils. It is light years ahead of your Holley 4D, faster chip, better resolution for tuning, wideband targets, data logging, etc. BTW your T/A is beautiful.
Rob
Takid455
09-20-2012, 12:15 PM
:scared: you know the plans....
Glad you appreciate the T/A . Need to update the thread being I am closing this chapter of the build. Going to enjoy the car a little before starting the next chapter. Pretty sure anything will be more sophisticated than the Projection installed however It's simplicity works. Ultimate plans are SEFI & DIS. Looks like BS3-004-026 or -021 would be what I would want. Dont see the add on box listed. Perhaps I am over looking it. Know where to look? Depending on size of ECU's and total cost, your system may work on the economical sense.
Larry
MrForce
09-20-2012, 01:26 PM
Larry
The part numbers you listed will work for COP, but not with a distributor. An XIM box from FAST will convert a single coil ECU to multi coils (yes any brand of ECU) allowing you the now and later set up you want. IMHO, converting a Gen 1 type engine to COP offers no performance advantage, and still requires a distributor of some sort to drive the oil pump and provide a cam signal.
Rob
alnoe
09-20-2012, 02:43 PM
Hi Rob
What is up? Long time no talk. Hope everything is well with you.
Bump for a great seller and one of the smartest EFI guys I know.
Al
MrForce
09-22-2012, 08:46 AM
Hi Rob
Al
Thanks Al, PM sent
