View Full Version : Need Spark Plug Wires for 69 Camaro w/ LS2 & Stainless Works Headers
rocketrod
09-15-2012, 09:26 AM
As mentioned I have an LS2 with Stainless Work headers. I have a set of MSD 32823 spark plug wires, but with the #5 wire installed about an inch of the boot is pressed up hard against the header.
I happened to have the stock 2008 TBSS plug wires and they will work if I trim some of the excess material from the #5 boot, but of course as luck would have it a couple of the wires are bad.
I know I could mix and match a set to fire up the motor, but I would rather buy the correct ones and be done with it. Any recommendations?
09-15-2012, 10:55 AM
MSD sells wire in bulk and in different lengths, you can swap the ends to the new wire. MSD also sells the ends in 2 packs, you can make a new set if you needed to.
diesel25lrs
09-17-2012, 10:52 AM
Rod,
I have a set of NIB stock GM LS3 wires that I switched out before I ever drove it if your interested? I had 2 that wouldn't clear my SW headers either so I used some small zipties to the coil bracket just to get them from laying on the header...
John@Texas-Speed
09-25-2012, 08:51 AM
If you are looking at MSD stuff their part number 32819 should work for that setup. It seems to me that you are using truck wires which would not match, unless you have a different head that I am not aware about.
