chevnut55
09-13-2012, 09:01 AM
I am looking for advice on what to do next on my cars brake problems.
I will start with my 69 camaro. I installed a stock upgraded style 4 wheel disc brake kit,installed a good working booster/master I removed from my 72 camaro. the pedal is hard and doesnt seem to be making enough line pressure. the vacc is good , I thought it was the cheap braided brake hose from summitt but I changed back to stock with little change.The brakes all work but the pedal is hard not running and only slightly better when running/holding a rpm.not much pedal travel maby 1/2" tops ... any ideas?
next my 55 chevy,
The ongoing problem I have been tring to solve for 6 months!
it had a front stock chevelle style disc swap in front but never stoped well..and it has 800+ hp!!! so I put a monte carlo dic in the rear ,installed all braided hoses,and a wilwood 1" master. it is mounted under the floor and has a duel diafram booster with good vacc, wilwood residue valves,and a adjustabe prop valve,it also has a linelock that went bad so its unhooked .
the problem is it still has a soft pedal until I pump the brake..almost to the floor. I blead it 1000 times , drove it to get the fluid hot and blead it, bought a pressure bleader and even let it gravity bleead, the master was bench blead 5 times and all the connections tightened and checked many many times. but still when the pedal feels good walk away and its back to the floor when I come back.
so brake guys....any ideas to keep me out of the nut house?
next my 55 chevy,
