Chevelle598bb
09-11-2012, 01:20 PM
I have a new in box xtreme energy 284 hydraulic flat tappet cam for Pontiac V8 engines. Part number is 51-225-4. I paid 145.00 for the cam and I am asking 110.00 for it. Specs are below. PM your email for pictures. I am located in North Texas. Thanks Jason.
Cam Style
Hydraulic flat tappet
Basic Operating RPM Range
2,300-6,500
Intake Duration at 050 inch Lift
240
Exhaust Duration at 050 inch Lift
246
240 int./246 exh.
Advertised Intake Duration
284
Advertised Exhaust Duration
296
Advertised Duration
284 int./296 exh.
Intake Valve Lift with Factory Rocker Arm Ratio
0.507 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio
0.510 in.
0.507 int./0.510 exh.
Lobe Separation (degrees)
110
Computer-Controlled Compatible
No
Grind Number
P XE284H-10
Cam Style
2,300-6,500
240
246
240 int./246 exh.
284
296
Advertised Duration
284 int./296 exh.
0.507 in.
0.510 in.
110
No
Grind Number
P XE284H-10
