67Camaro_Conv
09-08-2012, 04:26 PM
Hello Pro-Touring.com community,
I've been following PT for many years and recently registered in preparation for the start of my project. I've always had a lot of respect for what many of you have achieved with your projects, and I'm sure that I'll need to tap into this vast knowledge at some point during this process.
Up till now I've been researching parts and saving money. I'm finally ready to start buying parts (wow is this stuff is expensive!!) and I wanted to share what I've come up with so far.
The goal for the Camaro is to be a fun top-down cruiser with the majority of the budget allocated towards the mechanical bits and less towards body/interior enhancements. The car will eventually need paint and body work, but I'd rather not delay enjoying the car while I wait for my budget to allow for paint & body. And unfortunately the current mechanical condition is not suitable for safe and reliable cruising so I feel that doing the mechanical bits now is my best option, and the paint and body will come down the road.
This is the current (and still growing) parts list. If anyone sees glaring mistakes please let me know. I've researched these parts and I feel like I am on the right track, but I know many of you have tried these parts and your experience is priceless.
DSE 67-69 F-BODY UPPER CONTROL ARMS
$ 695.00
DSE 67-69 F-BODY LOWER CONTROL ARMS
$ 650.00
KONI FRONT SHOCKS (PAIR)
$ 125.00
DSE HOLLOW FRONT SWAY BAR
$ 210.00
HOTCHKIS FRONT SPRINGS
$ 168.72
DSE REAR SPEED KIT1 FOR MONO-LEAF INCLUDES; SPRINGS, KONI SHOCKS, BUSHINGS/ SHACKLES
$ 760.00
DSE BODY MOUNTS - STOCK HEIGHT
$ 115.00
DSE STAINLESS SUB FRAME/BODY BOLT KIT
$ 99.00
HOTCHKIS CHASSIS MAX SYSTEM, SUBFRAME CONNECTORS, CONVERTIBLE, KIT
$ 602.00
DSE STEERING BOX 12:1, NO FINISH
$ 595.00
DSE 3/4-30 RAG JOINT
$ 99.00
DSE FRONT END SERVICE KIT
$ 310.00
DSE P/S HOSE KIT FOR 600 BOX
$ 150.00
IDIDIT STEERING COLUMN, RETROFIT, TILT, STEEL, BLACK, CAMARO
$ 825.00
BAER TRACK-4 FRONT BRAKE KIT 13" ROTOR
$ 1,495.00
BAER SS4 REAR W/PARK BRAKE TORINO HOUSING ENDS 12"
$ 1,206.00
DSE BRAKE BOOSTER AND MASTER CYLINDER KIT
$ 395.00
MOSER 12 BOLT F-BODY WITH POSI WITH TRUE-TRAC
$ 3,000.00
LS3 CRATE ENGINE
$ 6,995.00
LS3 ENGINE CONTROLLER KIT
$ 1,219.00
ASSORTED PARTS FOR ENGINE
$ 1,500.00
BILLET SPEC TRU TRAC W/OUT A/C W/ POWER STEERING
$ 2,295.00
MAGNUM T-56 6 SPEED TRANSMISSION
$ 3,395.00
BELLHOUSING, QUICK TIME, SFI APPROVED, CHEVY 4.8/5.3/5.7/6.0
$ 558.00
THROWOUT BEARING, HYDRAULIC, GM, T-56
$ 349.00
MASTER CYLINDER, ADJUSTABLE CLUTCH, CAST
$ 351.00
STAINLESS STEEL FUEL TANK W/CAMARO FUEL PUMP
$ 1,500.00
FUEL SYSTEM TUBING, HOSES, WIRING AND FITTINGS
$ 600.00
CLASSIC67-8 CAMARO 2 GAUGE SET, VELOCITY BLK, CURVED LENS
$ 1,100.00
HEADERS, LS SWAP, MID-LENGTH, 1 3/4 IN. PRIMARY
$ 335.00
MUSCLEMAXX EXHAUST SYSTEM, STAINLESS STEEL,
$ 575.00
ALUMINUM DRIVESHAFT
$ 500.00
WHEELS
$ 2,000.00
TIRES
$ 1,000.00
Tony
Butternut 67 Camaro Convertible
$ 695.00
$ 650.00
$ 125.00
$ 210.00
$ 168.72
$ 760.00
$ 115.00
$ 99.00
$ 602.00
$ 595.00
$ 99.00
$ 310.00
$ 150.00
$ 825.00
$ 1,495.00
$ 1,206.00
$ 395.00
$ 3,000.00
LS3 CRATE ENGINE
$ 6,995.00
$ 1,219.00
$ 1,500.00
$ 2,295.00
$ 3,395.00
$ 558.00
$ 349.00
$ 351.00
$ 1,500.00
$ 600.00
$ 1,100.00
$ 335.00
$ 575.00
ALUMINUM DRIVESHAFT
$ 500.00
WHEELS
$ 2,000.00
TIRES
$ 1,000.00
Tony
