View Full Version : New Chevy 350 motor
DJW32
09-07-2012, 03:25 PM
Fresh GM 350 (Purchased from Selman Chevrolet)
Quadrajet Carb ( the carb shop)
HEI Dizzy
New GM starter
Sanderson headers
assy drive with ac, alt, power steering, and water pump from a 70 Chevy C-10
I have two different flywheels for this 350-1 for a turbo 350 and 1 for a 700r4
I bought this motor from GM. I may have put ONLY 400-500 miles on this motor. Also, I took this motor out for a LS 5.3.
This motor is a ready to run (turn key) motor. The motor comes complete from carb to oil pan.
I would like $2,100 for the complete setup.
Here are the specs on the motor:
Block: Cast iron, 2-bolt main, 1-piece rear main seal
Connecting Rods: Powdered Metal Connecting Rods
Pistons: Dished Hypereutectic
Compression Ratio: 9.4:1
Oil Pump: High-Volume Oil Pump
Timing Chain: Morse link-type
Camshaft: Flat Tappet Hydraulic (Lift .382" Int/.402" Exh; Duration @ .050" 165.9° Int/174.8° Exh; Lobe Separation Angle 111.9°)
Cylinder Heads: 65.3cc chambers, 1.94"/1.50" valves, swirl port intake design (heads are not performance-oriented; intended for good bottom end torque and fuel economy; intake runner is restrictive because it has a ramp cast into the bottom of the bowl to promote high swirl)
DJW32
09-08-2012, 01:29 AM
I should have mentioned that this is the 290 horse motor that can safely be run on 87 octane.
DJW32
09-24-2012, 07:42 PM
Bump for pics.
