View Full Version : II Much Fuel and Differential Vents are in stock and ready to ship
parsonsj
09-07-2012, 07:36 AM
The II Much Fabrication Vent solves several problems when installing high performance fuel tanks. It allows the use of an unvented fuel cap, preventing fuel slosh and odor, while providing filtered air to the tank via its integrated 40 micron filter. The Vent also works well as a differential vent, allowing the rear end assembly to breathe, and helping to eliminate differential fluid seepage and leaks.The new design allows for simple plumbing to a fuel tank or differential: mount the Vent, and connect it to the tank or differential vent port. It's that easy.
Go here to order: http://www.iimuchfabrication.com/fuel-system/fuelvent2.html
parsonsj
09-24-2012, 05:55 PM
Here's a pic of a recent twin vent installation we did in the fab shop:
https://static1.pt-content.com/images/pt/2012/09/trunkoutsideview-1.jpg
Read the whole article here: http://blog.iimuchfabrication.com/?p=297
parsonsj
09-27-2012, 12:25 PM
We've got a new blog entry up about part numbers for the hoses and fittings we used in our twin vent install:
http://blog.iimuchfabrication.com/?p=346
https://static1.pt-content.com/images/pt/2012/09/fuellineassembly-1.jpg
protour_chevelle
09-27-2012, 07:58 PM
order placed!
parsonsj
09-27-2012, 08:44 PM
Thanks Matt! Sorry about how expensive shipping to Canada is. The boys down Under pay $75. Yikes!
daredvl22
09-29-2012, 10:17 AM
JP,
Thanks for listing out the fittings w/ part #'s. This is exactly what I needed! I actually just ordered a Blair hole cutting set through Amazon, received it today. Good deal, around $100 part# 14006. Now all I need is everything else so I can install my vents! Thanks for going into such great detail, it helps more than you know!
ChevelleNV
09-29-2012, 01:09 PM
Dammit John, now I'm gonna have to get another one from ya....so I can do my rear diff too
Ron.in.SoCal
09-29-2012, 01:42 PM
MY thoughts exacltly. John for the diff, is there any specific advantage to your fuel vent over traditional vent solutions? Other than having a matching set, which helps with my OCD...:D
parsonsj
09-29-2012, 02:55 PM
Our vent will handle gear lube smell and keep your rear end nice and clean better than a "traditional" vent. But that's not really near as bad an issue as fuel smell and slosh.
Personally, I think everybody should run twin vents. :)
coolwelder62
09-29-2012, 03:50 PM
This is my II Much vent install.https://static1.pt-content.com/images/pt/2012/09/chevellebuild002-1.jpghttps://static1.pt-content.com/images/pt/2012/09/chevellebuild003-1.jpghttps://static1.pt-content.com/images/pt/2012/09/chevellebuild005-1.jpghttps://static1.pt-content.com/images/pt/2012/09/chevellebuild006-1.jpghttps://static1.pt-content.com/images/pt/2012/09/chevellebuild007-1.jpg
coolwelder62
09-29-2012, 03:54 PM
When I got my II Much fuel vent I was so Impressed I called and ordered a second for my diff vent.It is now installed on the other side of the trunk.Very good product.!!!!!
JohnUlaszek
02-20-2013, 11:25 AM
V8 TV has just posted an installation video on its wicked CoyoTBird project
RPn0vNp8TsY (http://www.youtube.com/watch?feature=player_embedded&list=PLGV8X9X8baVg-6raRmHC9Ut8UECWFr711&v=RPn0vNp8TsY)
